Old 06-27-2007, 11:14 AM
merawoods merawoods is offline
99 Alero window problems
I am having problems with my left passenger window. It will go down but will not go up. I can pull the window up by hand. The motor works and the cable works in both directions. The cable stays tight when moving. Has something come off the cable that pulls the window up?
please help
thanks
Old 07-03-2007, 06:43 AM
tbuckit1's Avatar
tbuckit1 tbuckit1 is offline
Send a message via AIM to tbuckit1
Re: 99 Alero window problems
You are probably looking at putting in a new window regulator. Not brain surgery and available at your local parts store for around 100 bucks.
T
"What in the wide, wide world of sports is a go'in on here?" - Taggert
Old 08-02-2007, 03:28 AM
gse2schmidt gse2schmidt is offline
got my regulator with motor for 35 bucks plus 15 for shipping on e-bay(doesn't the factory like to get like $300 for the pair?)
takes about a half hour to replace
Old 08-09-2007, 11:26 PM
rnj rnj is offline
Send a message via MSN to rnj
I had this happen to both my doors. I purchased the regulator clips from stealership, not cheap, $35 bucs apiece. It only took me about 40 mins total to replace. If you do take the door panel off. Look behind the red plastic reflector lens or whatever it is, but it is in the bottom corner of the panel. Pry it off, there should be a hidden screw in there. Learned that the hard way . If you need the sach clips, you can still replace it, I had one break, and did replace it succesfully. But I just saw a pack of 4 at advanced auto in the help section for 7 or 8 bucs. I bought 1 at stealership for 10...again .
