Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-27-2007, 12:44 AM
93*Corvette 93*Corvette is offline
96 Jimmy - AC thru Defroster only - I have vacuum-What else?
My 96 Jimmy has cold AC. The only problem is it come out the Defroster vent only. I checked for vacuum at the dash switch and I have vacuum. I decided to replace the switch since I though since it had vacuum then it had to be the switch. It wasn't.
I was about to replace the "Ball" mounted on the hood, but since I have vacuum I can't believe that would be faulty. But, I'm at a loss now. What would cause the vents not to operate?
Old 07-03-2007, 07:37 AM
Lion's Amigo Lion's Amigo is offline
Re: 96 Jimmy - AC thru Defroster only - I have vacuum-What else?
I am having the same problem only mine is stuck in between vent and defrost. But it won't move no matter what I select. If you find an answer I want to hear it as well.
Old 07-14-2007, 10:44 PM
YohDave YohDave is offline
I've just had the same issue today, same year, same model. Keep me updated on your progress. I haven't been able to figure it out yet.
Old 07-22-2007, 08:11 PM
pappyl pappyl is offline
have an older Jimmy, but I do not not believe they've changed this too much.
- The main vaccuum from the engine goes through the firewall and connects up to the rotary control switch. This switch acts as a valve, directing vacuum to the other lines (usually 5).
1 for defrost
2 for directing middle vents
1 for fresh air vent in (diaphragm outside of firewall)
1 for a/c recirc
- each line connects to a vacuum diaphragm which (when vacuum applied) contracts a control lever, which closes a gate in the plenum (depending which diaphragm, directs air to feet, main vents, or defrost).
So what goes wrong?
- A line is disconnected, and vacuum is lost, gate does not open
- Insulation on a plenum door comes off and closes off an opening *yes this happens
- A vacuum diaphragm is faulty
- Switch is faulty.
- A spring, hinge, or control lever is faulty on a gate, which causes it to bind/not move
- someone was playing around and switched the lines at the control switch
Defrost, to my knowledge, is not "normal" state which indicates a bad gate in the plenum. "Normal" state is when all vacuum is OFF and gates are in retracted position. The air is being diverted because a gate is stuck.
Try pulling the controller, and the vacuum line connectors. Use a small patch vacuum line with 1 male ends.
Start the engine, put fan on high, and find the source vacuum. Systematically apply vacuum to each line with the patch line and listen for a door in the plenum opening, redirection of air, etc.
When nothing happens, that means you have a problem with that particular line and will probably need to yank the dash and pull the plenum (given the vacuum line has no leaks).
Applying full vacuum to a diaphragm, then disconnecting - on/off may jog it from a bound position.
Let me know if this helps.
