Old 06-26-2007, 08:57 PM
snicker64 snicker64 is offline
2001 Intrigue 3.5 engine
What should the fuel pump preasure be on this car.
Old 06-26-2007, 10:23 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: 2001 Intrigue 3.5 engine
I couldnt find the exact numbers, it seems like I once posted them but I couldnt find it.
Should be in the high 30s to low-mid 40s, thats pretty well considered normal.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 06-26-2007, 10:44 PM
We have had a lot of trouble getting this car to start. It will crank and crank before it will start,if it starts at all. Replaced the CKS today and the car started,but had no power on hills just kept slowing down like it wasn't getting enough gas to pull. Checked the fuel preasure with the engine running it ran at 36 lbs. Have any ideal what other problem we should look for.
Old 06-26-2007, 10:54 PM
LittleHoov's Avatar
That does seem a shade low, what sort of gauge were you using? Im asking because low quality gauges will often give inaccurate numbers.
After you turn the car off do you smell gas at all? Check the vacuum hose that goes to the Fuel Pressure Regulator for fuel, if there is fuel in that line the FPR is defective. Also check your pressure readings with that same vacuum hose connected and disconnected. Pressure should get higher with the hose disconnected. If the swing is very large 7-8 PSI, you might try changing out the FPR, although that brings me back to my original point of making sure youre using a quality gauge.
With those lower readings, start simple by changing out the fuel filter if you havent already.
Also Im just curious, did you get a check engine code for the CKPS? Because I have been having trouble with mine starting right lately. It will fire, but run very poorly unless you give it a little gas, usually it starts then dies, then you have to crank it again a little longer than normal and it will start and run fine. Im just asking for my own benefit, because im considering replacing that sensor.
Old 06-26-2007, 11:06 PM
I am using a Actron 100 lb fuel testing gauge. I chacked the fpr today no gas in the vacuum line to the fpr. Didn't smell any gas. When we had the code scanner plugged it coded that there was no signal coming from the cks that is why we replaced it. The car wouldn't start untill we replaced cks. My daughter just called and said that it wouldn't start now. Cleaned the throtle boby also. Put new ac plugs in it,new fuel filter and new air filter.
Old 06-26-2007, 11:38 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Littlehoov - your symptoms sound exactly like a FPR
2003 Pontiac Grand Prix 3.8 Litre V6
ASE Certified Master Tech
Old 06-27-2007, 12:21 AM
kmohr3's Avatar
For what it's worth, page 6-876 of the manual says fuel pressure (engine off, but pump running) should be 48 - 55. However, on page 6-884 it says 41 - 47. It also mentions the fuel pressure would be 3 to 10 lbs less when vacuum is applied to the FPR.
AllData also says 41 - 47 (engine off, fuel pump running). This makes me think your fuel system might be OK.
Maybe your loss of power is related to a restricted exhaust and/or plugged cat converter? Is it possible that it may have an intake gasket / internal coolant leak problem? Check for engine coolant and engine oil possibly mixing somehow. Check for oil in the coolant or coolant in the oil. When it does start, does it idle well? Is a 'check engine' light on? How many miles on this car?
Old 06-27-2007, 08:15 AM
The engine idles well when it starts, It has 96,000 miles on it. There was one other thing that happened yesterday when i took the throtle body off of the car to clean it. When i loosened the nuts on the throtle body and began to remove it gas sprayed from around the bottom of the throtle body and stood on the back of the transmission seem like quiet abit of gas to me. I don't know but this didn't seem normal to me for gas to be coming out from around the throtle body. I might be wrong but i throught that air is what went through the throttle body. I forgot about this happening until this morning. When it start misfireing the service soon engine light will flash and come on. Had that checked too multibles misfires is all that coded. Haven't found any coolant leaks. The oil is fine no coolant in the oil.
Old 06-27-2007, 10:27 AM
kmohr3's Avatar
only air flow and coolant - to my knowledge, go thru the throttle body. Maybe the FPR may have vented thru the vacuum line attached to the throttle body? Just a guess?
If it was my car I would think about pulling the plugs again after the engine has completed a run cycle and 'read' the spark plugs. maybe you could tell if 1 or more is black - indicating overly rich. Maybe check compression while they are out.
Old 06-27-2007, 11:04 AM
The car won't start again. When i pulled the throtle body i didn't see any coolant just fuel running out. I will pull the plugs again and see if they are wet with fuel. The FPR only had one vacuum line on it that i could see. Is the FPR the only way that fuel can get into the air intake?
Old 06-27-2007, 04:44 PM
kmohr3's Avatar
my daughter had a 98 with the 3.8 motor that had an injector stick wide open. I think you'd smell or see fuel before long. It even filled the exhaust with fuel. The way I found it was when doing a compression check and cranking the motor it was blowing fuel out the spark plug hole.
Be careful when playing with open fuel system, have a fire extinguisher handy.
maybe it's possible the FPR is intermittently feeding the intake with fuel thru the vacuum line??
Old 06-27-2007, 04:56 PM
Went back out to my daughter's today,pulled the plugs out and all of them were black and dripping with fuel. Did a compression test and the cylinders were running about 180 lbs. Drid the plugs and reinstalled them the engine started to hit then it started and ran for a few minutes. Then it died and wouldn't just hit ever now and then just like it was flooded. You could smell raw fuel under the hood. Seems like it is getting to much fuel. What do think?
Old 06-27-2007, 06:58 PM
kmohr3's Avatar
I think I'd be looking for a stuck wide open injector(s), or possible fuel pressure regulator leaking into the vacuum line - dry off the plugs again, and start it with the vacuum line for FPR removed.
I've had to pull fuel rails off certain cars with injectors installed to see what the injectors are doing during cranking, and/or when pump is energized.
Use caution when doing these types of tests!
Old 06-27-2007, 07:36 PM
How can i tell if the injectors are open. Today when i did the compression test it was blowing fuel out of the cylinders. I have the FPR ordered from rock auto so i will replace it when it comes in. I still haven't figured out where the fuel came from when i took the throtle body off. Ther is a switch or regulator right behind the throtle body on the intake manifold on the firewall side of the car set right in front of the FPR. When you turn the key on sounds fuel running throuh this switch or regulator it has a fuel line attached to it and has a electrical plug also. Have ant ideal what this. I will dry the plugs off and try to start it with the vacuum line disconnected from the FPR and see what happens.
Old 06-27-2007, 07:58 PM
kmohr3's Avatar
I've done this on VW jettas and not an Intrigue. But what I did was pull the fuel rail loose from the intake leaving all the injectors and wiring and fuel lines attached to the rail. I would move the assembly away from the intake enough to visually inspect the injector spray.
First, I would power up the pump with the engine off. If you have one spray at that time it is probably stuck open. I have also cranked the motor when looking at the injectors to make sure all of them have an equal, pulsing type of spray.
Be very careful when doing this because the atomized spray can easily catch fire from a hot manifold or ignition spark from a coil, wire, or plug. It would be very easy to burn yourself, your car, or your garage/house!!!!
I'm wondering if a bad PCM could make the fuel system dump fuel into the engine via the injectors? Any GM techs out there seen this?
