I have a 2000 Grand Am 2.4L. Bought it used 2 years ago started out with problems with the ignition where if I did not turn the key completely vertical the car would still be on and the battery would die. I had to take the gear shift and push it forward some to lock into a completely "off" ignition switch. Eventually this ceased being a problem. About a year ago I replaced the fuel pump after the car died. Now I am having a problem where the car will die at a stop. No overheating, no change in idle- just dies. Then it started to sometimes require multiple attempts to start. Sometimes 20 or more with waiting too. The mechanic could not reproduce the problem when I brought it in. Finally it was not able to start and the battery was replaced. Ran great for about a week now I am back to 2-3 tries to start it and just had one of those 20 times to start befor something finally went through. I guess when the battery is changed the codes are lost and no one seems to be able to diagnose this mystery- computer? Ignition? something in the wiring between the battery and the ignition? I see I am not completely alone in this problem. Help!!!
Re: Grand Am Dies No one knows what is wrong
Hey Brother Same Problem Here And Im Stuck Find Anything Out?
Welcome to AF, thin on info here, stalls repeatedly restarts ok,? Also post engine size.
Sounds like a passlock issue, good Luck! !
1999 Grand Am SS 3.4 OHV
