Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-26-2007, 04:00 PM
Eddie57 Eddie57 is offline
Trouble Code
Can someone out there tell me what error code 2292 means?
Thanks
Old 06-26-2007, 06:03 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Trouble Code
Year and engine size please.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-26-2007, 09:13 PM
Re: Trouble Code
2002 Ford Explorer, 6 cylinder, the Air bag light has been coming on for some time but don't know what exactly is the problem. I know the Stealership will fix it, but they are so expensive. Any help is appreiciated. TIA
Eddie
Old 06-26-2007, 09:41 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Trouble Code
Eddie
So is the code you posted an SRS code or an engine code? Ie: what is the prefix, P, B, or U such as P2292, B2292, or U2292?
I don't believe the P codes go that high (last one I see is a P1900) so I'll assume with the information re: air bag light, this is a B2292. With that assumption, the service manual states the code is a driver's side seat belt pretensioner circuit fault.
-Rod
Old 06-27-2007, 08:36 AM
Re: Trouble Code
Hey Rod, Yes the code was B2292. I am not an expert by any means. Just your basic do it yourself guy. Not sure what the seat belt pretensioner circuit fault is or where it's at. Can you give me some more information on this? Maybe a link or a picture if you have one accessible. Is it something I can do or will a professional be needed? I really appreciate your help.
Thanks again,
Eddie
Old 06-27-2007, 01:21 PM
shorod's Avatar
SHO No Mo
Re: Trouble Code
If you would send me a private message with an e-mail address for you that can accept PDF attachments, I can send you the diagnostic procedure and some diagrams.
-Rod
Old 06-27-2007, 10:53 PM
shorod's Avatar
SHO No Mo
Re: Trouble Code
The procedure is on its way to the e-mail address you provided.
Good luck!
-Rod
Old 06-28-2007, 09:08 AM
Re: Trouble Code
Thanks Rod. I really appreciate it. I'll take a look at it at my first opportunity.
Eddie
Old 07-19-2007, 10:35 PM
jacobunderwood jacobunderwood is offline
Re: Trouble Code
that is going to be a manufacuture specific code
Old 07-20-2007, 08:45 AM
Re: Trouble Code
Not sure what you mean by your reply. I am not very familiar with codes. Just a basic change your on oil guy. Can you elaborate.
TIA
Old 07-20-2007, 01:28 PM
shorod's Avatar
SHO No Mo
Re: Trouble Code
All that means is that it's not a generic code common to all OBD-II systems, but rather it's a code that may have a different definition between the different manufacturers.
A code such as P0123 would be a generic OBD-II powertrain code. The generic codes are designated by a '0' in the thousands place. If that '0' is something other than zero (ie: P1123) then it is a manufacturer specific code.
That being said, the definition I provided you in post #4 is still accurate as I pulled the information from the Manufacturer's service manual.
-Rod
Old 07-20-2007, 02:19 PM
Re: Trouble Code
Thanks again.
Have a good weekend!
