Old 06-26-2007, 02:37 PM
jasonb21 jasonb21 is offline
Intake Air Temperature Circuit High Input
i just left the ford dealership but can anytell me what this is and and how to fix it Intake Air Temperature Circuit High Input
thanks
Old 06-26-2007, 03:08 PM
12Ounce 12Ounce is offline
Re: Intake Air Temperature Circuit High Input
Intake Air Temp (IAT) sensor mounted in the air intake system, usually in the bellows just after the air filter. Later models have the IAT sensor and the MAF (Mass Air Flow) sensor mounted together as one plug-in unit.
Old 06-26-2007, 03:10 PM
can i change this myself and is the high and low input the same thing i got both codes the first time then reset then only got the one.
Old 06-26-2007, 03:55 PM
Its pretty easy to remove and replace. Make sure the harness wiring is in good shape ... not broken, skinned covering, etc.
Some folks have had good luck cleaning these sensors with printed circuit board cleaners ... might want to give it a try. It takes just a piece of dust to run these things crazy. Proper and frequent air filter maintenance is important for the protection of these sensors. Of course they just fail on their own sometimes, also.
Old 06-26-2007, 04:28 PM
RickMN RickMN is offline
The intake air temp sensor is indeed inside the MAF sensor. I recommend using CRC MAF sensor cleaner. Remove the MAF sensor from the ductwork and disconnect the wiring harness. Inside the opening you will see a small circular portion port. Spray that liberally with the cleaner. They recommend 15 sprays. Then allow it to dry before re-installing. Cleaning solves a lot of problems, especially if you drive around with a dirty air filter or have a reusable oiled cotton air filter. Fibers from those filters blow off and fry on the hot wire inside the MAF. Sometimes it coats the IAT thermistor and insulates it. If this doesn't solve your problem, there are some digital meter tests you should conduct before you condemn the $300 MAF sensor. Let us know how it turns out and we can walk you through the additional testing.
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology.
