Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 06-26-2007, 02:23 PM
yupang21 yupang21 is offline
96 Skylark key and ignition problems
Lately I have had problems with my key getting stuck in the ignition. The car its self would start fine but when I would try to get the key out it would not come out. The key would get stuck at the point were some of the dash lights would come on but the radio would still be off.
So I would just leave the key in the ignitionfor a period of time any were from 10 minutes to an hour and when I would try to remove the key it would come out after sitting for awhile.
But as of about a week ago the key would not come out at all evan if I would let it set for awhile.
But today my car will not start I mean I have power to the car radio starts and everything but when I try to start it I just hear a rapid clicking sound "probley the starter" and that’s it. Oh and my key comes out now if that helps at all.
It would be greatly appreciated if someone could help me fix the problem.
Old 06-26-2007, 03:26 PM
marc-o-matic marc-o-matic is offline
Re: 96 Skylark key and ignition problems
The rapid clicking is caused by low voltage(low battery or bab connection).
Check battery cables @ battery/charge or replace battery.
As far as the key problem,most likley need new lock cylinder.
HTH
Marc
Old 06-26-2007, 03:43 PM
Scrapper Scrapper is offline
AF Premium User
Re: Car key and ignition problems
sounds like you need a new ignition switch or cylender they call it...good luck..
Old 07-02-2007, 09:48 AM
Tom_SF Tom_SF is offline
Buick Owner
It does sound like the starter. You should also get the ignition switch changed too. You might fry that thing if you keep trying to start it. There was also a recall to add a relay to prevent back-current from doing that. Check with a dealer's service center.
