Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 06-26-2007, 10:37 AM
bubba4life bubba4life is offline
airbag lite problem 1992 town car
ever since i got my 1992 the airbag lite has blinked. it will blink 7 times, then stop for a second then blink 7 times. do any of you know what that error means.
Old 06-26-2007, 01:46 PM
Towncar's Avatar
Towncar Towncar is offline
Re: airbag lite problem 1992 town car
Interesting.... The 1992 manual doesn't include code 77 in the diagnostic subroutines.
The charts show lamp codes:
None (no lamp)
Solid (continuous lamp)
12, 13, 14
21, 22, 23, 24
32, 33, 34, 35
41, 42, 44, 45
51, 52, 53
99 (1) *continuous fast flashing
But no 77
-Steven
1996 Town Car, Cartier
Old 06-26-2007, 05:07 PM
i went back to my car to make sure i counted right and now the airbag light isn't flashing. sometimes after i drive it a while it goes off but then the next morning it usually comes on again. so next time is starts to blink again i make sure to double check the number of times it blinks
Old 07-06-2007, 09:58 AM
i finally remebered to count the flashes. and the airbag light just keeps flashing 7 times non stop. any help would be awesome the light is driving me nuts.
Old 07-12-2007, 01:14 PM
TheFear076 TheFear076 is offline
I sometimes have this problem with my 91 TC. Its done it for over 2 years now and hasnt appeared to cause any problem. But i guess if i get in a crash and my air bag doesnt deploy ill know why lol.
Old 07-12-2007, 05:00 PM
Towncar's Avatar
You might try calling a dealer service department, asking what code 77 means on your 1992 TC, maybe they'll refer you to some expert -
All I can see on this subject is the 1992 diag. charts. and procedures.
I'd love to post a 77 procedure, but there isn't one
-Steven
Old 07-12-2007, 06:50 PM
well last weekend we went to a weeding in another town and my dad was driving and i noticed the light blinking 10 times over and over again. and now that my check engine light keeps comming on less than a minute after i start it usually under a minute, then goes off after like 30 seconds. anyway i am going to take my car into a shop i know does good work and he will hook it up to a computer and see what the problem is for $45, i get a discount through my friend. so maybe next week i'll finally know why the airbag light blinks and check engine light comes on.
Old 07-13-2007, 12:23 AM
Channel595 Channel595 is offline
Send a message via AIM to Channel595
on my 91 the air bag light will come on during the bulb check and then turn off normally but i noticed it will blink ocaisionally(usually over uneven road surfaces) and then one day i noticed that the sensor on the inside of the front left fender wasnt bolted down all the way so i bolted it down tight and the light stopped blinking
Old 08-03-2007, 05:21 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Hi, I have a '95 TC and it has a flashing code too, don't remeber if it's 52 or 53 (i'll check that later to be sure), but what does each of these two codes mean? Thanks in advance.
Old 08-03-2007, 05:45 PM
Towncar's Avatar
Here's the Index Table of Contents:
Pinpoint Tests
PINPOINT TEST A: NO AIR BAG INDICATOR -- INOPERATIVE INDICATOR CIRCUIT (Index)
PINPOINT TEST B: CONTINUOUS AIR BAG INDICATOR -- DIAGNOSTIC TROUBLE CODE TIMED OUT, OR DIAGNOSTIC MONITOR DISCONNECTED OR INOPERATIVE, OR NO IGNITION VOLTAGE TO DIAGNOSTIC MONITOR (Index)
DTC 12: LOST BATTERY FEED (Index)
DTC 13: AIR BAG CIRCUIT SHORTED TO GROUND (Index)
DTC 14: PRIMARY CRASH SENSOR CIRCUIT SHORTED TO GROUND (Index)
DTC 21: DIAGNOSTIC MONITOR NOT MOUNTED TO VEHICLE PROPERLY (Index)
DTC 22: SAFING SENSOR OUTPUT CIRCUIT SHORTED TO BATTERY VOLTAGE (Index)
DTC 23: MEMORY CLEAR CIRCUIT IMPROPERLY GROUNDED (Index)
DTC 24: SYSTEM DISARM FAILURE OR INTERNAL DIAGNOSTIC MONITOR FAULT (Index)
DTC 32: DRIVER SIDE AIR BAG CIRCUIT HIGH RESISTANCE OR OPEN (Index)
DTC 33: PASSENGER SIDE AIR BAG CIRCUIT HIGH RESISTANCE OR OPEN (Index)
DTC 34: DRIVER SIDE AIR BAG CIRCUIT LOW RESISTANCE OR SHORTED (Index)
DTC 35: PASSENGER SIDE AIR BAG CIRCUIT LOW RESISTANCE OR SHORTED (Index)
DTC 41: RH RADIATOR PRIMARY CRASH SENSOR FEED/RETURN CIRCUIT OPEN (Index)
DTC 42: LH RADIATOR PRIMARY CRASH SENSOR FEED/RETURN CIRCUIT OPEN (Index)
DTC 44: RH RADIATOR PRIMARY CRASH SENSOR NOT MOUNTED TO VEHICLE PROPERLY (Index)
DTC 45: LH RADIATOR CRASH SENSOR NOT MOUNTED TO VEHICLE PROPERLY (Index)
DTC 52: INTERMITTENT OR REPAIRED LOST BATTERY FEED (Index)
DTC 53: INTERMITTENT OR REPAIRED AIR BAG CIRCUIT SHORTED TO GROUND (Index)
DTC 54: INTERMITTENT OR REPAIRED PRIMARY CRASH SENSOR CIRCUIT SHORTED TO GROUND (Index)
DTC 61: INTERMITTENT OR REPAIRED DIAGNOSTIC MONITOR NOT MOUNTED TO VEHICLE PROPERLY (Index)
DTC 62: INTERMITTENT OR REPAIRED SAFING SENSOR OUTPUT CIRCUIT SHORTED TO BATTERY VOLTAGE (Index)
DTC 63: INTERMITTENT OR REPAIRED MEMORY CLEAR CIRCUIT IMPROPERLY GROUNDED (Index)
DTC 64: INTERMITTENT OR REPAIRED SYSTEM DISARM FAILURE OR INTERNAL DIAGNOSTIC MONITOR FAULT (Index)
DTC 72: INTERMITTENT OR REPAIRED DRIVER SIDE AIR BAG CIRCUIT HIGH RESISTANCE OR OPEN (Index)
DTC 73: INTERMITTENT OR REPAIRED PASSENGER SIDE AIR BAG CIRCUIT HIGH RESISTANCE OR OPEN (Index)
DTC 74: INTERMITTENT OR REPAIRED DRIVER SIDE AIR BAG CIRCUIT LOW RESISTANCE OR SHORTED (Index)
DTC 75: INTERMITTENT OR REPAIRED PASSENGER SIDE AIR BAG CIRCUIT LOW RESISTANCE OR SHORTED (Index)
DTC 81: INTERMITTENT OR REPAIRED RH RADIATOR PRIMARY CRASH SENSOR FEED/RETURN CIRCUIT OPEN (Index)
DTC 82: INTERMITTENT OR REPAIRED LH RADIATOR PRIMARY CRASH SENSOR FEED/RETURN CIRCUIT OPEN (Index)
DTC 84: INTERMITTENT OR REPAIRED RH RADIATOR PRIMARY CRASH SENSOR NOT MOUNTED TO VEHICLE PROPERLY (Index)
DTC 85: INTERMITTENT OR REPAIRED LH RADIATOR PRIMARY CRASH SENSOR NOT MOUNTED TO VEHICLE PROPERLY (Index)
Rapid Continuous Flashing of Air Bag Indicator -- Both Primary Crash Sensors Disconnected
Diagnostic Trouble Code Clearing
These subroutines are pretty lengthy, you can get a copy of this 1995 Service Manual CD ISO through my web page.
-Steven
Old 04-21-2010, 03:02 PM
olopezm's Avatar
Pinpoint Tests
Altough it's been a very long time, thank you very much for your help.
