Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 06-26-2007, 03:39 AM
gilbert3769 gilbert3769 is offline
89 olds 98 problems when driving
i have this 1989 olds 98 still and have replaced the fuel pump, fuel fitler, fuel pressure regulator, tps, coil pack, icm, ecm, plugs, plug wires. but still when im start it i get in and drive it around 2 blocks and when i press the accelerator at the stop sign the car will bog down and sometimes die. the codes it gave me where 21,22, 34 which the book said are grounded or open circuit in the map sensor, grouned or open circuit in the tps, and bad map sensor but my car does not have a map sensor. but when i put in the new tps for one day the car ran ok act up a little here and there but no check engine light i changed the oil that day and parked it but when i went out to check it the next day same prob with the same codes could it be the idler control sensor or any other ideas please help
thank you
Old 06-26-2007, 01:32 PM
maxwedge maxwedge is offline
A990 racer
Re: 89 olds 98 problems when driving
Have you done any diagnosing here? The 34 is the MAF sensor in the air duct, common problem on these cars. Disconnect it and see if the symptoms change.
Old 06-27-2007, 02:14 AM
i have unplugged the maf and it has the same symptoms but way worse so im going to purchase one this week will let you know how it goes
Old 06-27-2007, 03:52 PM
i replaced the maf but still same prob with a code 21 an 22 grounded or wide open tps circuit how do i fix that i jus got a new tps could that be bad or is it in the wiring
Old 06-27-2007, 08:14 PM
A990 racer
Check for 5v reference to the tps, ground and output form the tps. If you are unfamiliar with this process, go to autozone.com repair guides for the basics.
Old 07-07-2007, 03:24 PM
ok i found out that the tps plug was half way melted so i replaced it and now im only getting a 22 and i did the 5v reference with the voltmeter and it was at exactly 5.0 so could the bad plug have ruined the tps??
Old 07-07-2007, 04:29 PM
Mickey#1 Mickey#1 is offline
Don't you have adjust the TPS to read between .45 & .5 with the throttle closed?
Old 07-07-2007, 05:08 PM
A990 racer
Correct, he is reading the reference voltage.
Old 07-08-2007, 04:05 AM
no this tps you can not adjust some cars you can and some you cant and you cant on this one
Old 07-08-2007, 08:40 AM
You can still put a meter on the sensor & check for the 1/2 volt reading.
