Old 06-26-2007, 03:31 AM
russ_95670 russ_95670 is offline
vr4 motor oil
i live by mobile one full syn and i always use oem oil filters, what weight do you guys suggest and what do you guys use on your cars.
Old 06-26-2007, 01:10 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
Re: vr4 motor oil
i've herd from 10w-30,10w-40, and 15w-50
Old 06-26-2007, 01:24 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: vr4 motor oil
depends on your car.. stock vr4.. run 10 30... if you have mods and want a little more protection.. run some 10 40... if you have lots of mods.. maybe bigger turbos.. higher boost run some 20 50.... things to keep in mind.. if you didnt have lifter tick before and you add 20 50 and it starts making noise.. then its to thick.. the oil pin holes on the lifters are small on our cars... 91-98 anyway..
Old 06-26-2007, 06:49 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: vr4 motor oil
I use nothing but 20W-50 in the SL and the VR4, always have...it's what the book calls for.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 06-26-2007, 07:10 PM
AutostradaVR4 AutostradaVR4 is offline
Re: vr4 motor oil
mobil 1 15W-50.
but honestly it depends on how and in what weather you drive your car. There is a link in the FAQs that will tell you all about it. Basically, the larger the range between the 2 numbers, the more versitile the protection. Which means a 5W-50 oil will flow quickly on cold start to lubricate everything, and will have a thick layer of protective coating when warm. The downside of something like that is that it breaks down faster, so youll need to keep up on changing it, and its expensive.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
