Old 06-26-2007, 02:19 AM
mr3000 mr3000 is offline
crazy??
instead of doing a complete 6G74 swap into my N/A, i was wondering if my block could be bored enough to accommodate the 6G74 3.5L pistons?
Old 06-26-2007, 02:38 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: crazy??
nope. the max the block can be bored to is around 3.15L
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-26-2007, 02:45 AM
Re: crazy??
what would the power differences be with the 3.15L compared to the 3.0?
Old 06-26-2007, 01:03 PM
Linebckr49's Avatar
Re: crazy??
probably 10-30 hp. but if you're gonna rebuild it, do it right. if rebuilding, i would consider forged pistons, cams, etc. but that's not cheap.
93 3000GT base
