Old 06-26-2007, 12:15 AM
s2pidluv4u s2pidluv4u is offline
fog light type bulbs please reply need help
hi i own a 1995 3kgt base model and was wondering what kind of fog light bulb does it use is it H3 i am planning to buy yellow bulbs for it the stock one sucks ass and how do u replace the blubs i tried taking it out but its sooooooo confusing please help me and if u do have a tutorial or pics please send it thanks
Old 06-26-2007, 12:56 AM
mr3000 mr3000 is offline
Re: fog light type bulbs please reply need help
yea they are H3's
Old 06-26-2007, 01:34 AM
dhrubio's Avatar
dhrubio dhrubio is offline
Send a message via AIM to dhrubio
hmm idk what kind of fog lights you have, but they should be very easy u just need a philips screwdriver n thats it!
Pics
Old 06-26-2007, 02:16 AM
i have the stock fog ones for the 1995 how do i change the light bulbs what philips screw driver do i have to remove the front bumper? can any1 show me how like a pic or somthing thanks in advance
Old 06-26-2007, 03:12 AM
dhrubio's Avatar
you dont need to take off the bumper or anything else, except the fogs...u need this
just sit down in front of ur car, bend forward, look at the foglight, and youll see a couple screws around it...unscrew them, pull the fog light out a little bit (two wires will be connected, so u cant pull too far)...then take out 4 screws from the little black box inside the foglight u just pulled away, and it should be separate...and switch the bulb......just go out there and do it, you dont need to know anything to do this
Pics
Old 06-26-2007, 09:49 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
I love the picture man.. thats some crazy tool you got there haha
Old 06-26-2007, 11:53 AM
dhrubio's Avatar
i know, lets hope he can find one :-/
Pics
Old 06-26-2007, 11:54 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
on the 91-93 foglights, there are actually 10mm bolts with a philips screw head in the middle. if the screwdriver strips the head, you can always use a 10mm socket + rathet + extension to remove the bolts. not sure how the foglights are setup on 94+ cars.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-26-2007, 12:02 PM
dhrubio's Avatar
yea i forgot to say BE CAREFUL when taking out the screws!!! on my 94 its very easy: just 3 screws
Pics
