Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-25-2007, 09:30 PM
94HeavyChevy 94HeavyChevy is offline
headers???
where can i find headers that fit for a 94 caprice with a 350...should i get longtubes or shorties? what is the difference between the two?
Old 06-25-2007, 09:43 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: headers???
longtube is what you'd be better off with, unless room is an issue, then shorties will work.
Old 06-26-2007, 05:10 PM
Re: headers???
ok but exactly what brand and where can i find some...i have looked all over and last summer ordered some from jegs but they did not fit at all...not even close
Old 06-27-2007, 11:12 AM
PeteA216's Avatar
Re: headers???
Don't order from a catalog (online, or traditional) until you've done some research as to what fits. Edelbrock had a vast selection of headers with dofferent coatings, finishes, sizes and applications. I think Holly makes headers as well as do other manufacturers such a Summit, Weiand, Hooker, Flowtech, JBA, Flaming River, & Thorley.
Old 06-30-2007, 07:24 AM
96capricemgr 96capricemgr is offline
Re: headers???
Is emmisions inspection a concern? If so then shorties it is. If not then you can look at middlength or longtubes.
With the proximity of things like the AC lines and ABS lines to the headers ceramic coating should be considered manditory.
This is a part where cheaper will likely mean more work and expense to install, the headers specific to this application that fit really well and install easily with boltin pipes or cats to the existing catback, are hand built from thick tubing and are expensive. You can make headers meant for a second gen Camaro work in many cases but most are thin tubing, thin flanges, all will require costom work to hookup to the exhaust, some might require a bit of grinding on the suspension brace.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
Old 06-30-2007, 12:18 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: headers???
not to mention constant retightening of the header flange bolts, due to that thin tubing and flange.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-02-2007, 10:56 AM
Re: headers???
are they worth the trouble of getting and installing...should i give up on them or get them?
Old 07-02-2007, 04:52 PM
silicon212's Avatar
Confoundingly Lucid
Re: headers???
In your cars' case, that's a decision that you have to make. If you're not going to go spinning that thing near redline most of the time, I personally wouldn't waste my time. I've only owned one car in my life that I put headers on, and they were back off that car less than 36 hours after they went on.
Will they increase performance and economy? To a point, yes - but you also have to consider the possible consequences to running headers. They give a LOT of heat inside the engine bay - into the realm of 'copious quantities of it' - heat that you WILL feel radiating from the firewall and down into your lower extremites (feet, legs). If you don't get good, expensive headers, you will be replacing gaskets and torquing bolts on a regular basis. You will also have to re-route your plug wires to keep them off of the headers and remember that with the OptiSpark on your car, the distributor is at the front, behind the water pump.
