Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 06-25-2007, 08:31 PM
InnerDragon103's Avatar
InnerDragon103 InnerDragon103 is offline
Send a message via AIM to InnerDragon103
speed sensor... what do you think
one day my speedometer and odometer completely crapped out, moments after i accidentally stalled my car from not giving it enough gas ( i have a 94 gxe 5 speed)....
check engine light came on the next day... a few days later i pulled the code, got a speed sensor code and a knock sensor code. so i pull the speed sensor and test the resistance and the voltage pulse as you rotate the pinion, and got the appropriate reading...
HOWEVER, the plastic pinion sitting on the shaft of the speed sensor is kinda chewed up a bit, the gear teeth are bent up and i guess since its plastic it warped that way... its pretty bad. i mean only a portion of the pinion's teeth are messed up, not all the way around, but is it still enough to create problems like this? do you think that if i replace that plastic pinion the speedometer and odometer will work again? or perhaps there is a fuse i should test or something? my cluster works with the exception of speedometer and odometer, and check engine light came on for speed sensor the day after those two things broke.
~1994 Altima GXE 5 speed~
Current mods:
Short Ram Intake
Tint
8500K headlights
New sound system, 2 12" subs (600W)
Old 11-28-2007, 03:48 PM
Re: speed sensor... what do you think
so i bought a new plastic cog and replaced the old chewed one, however the speedometer and odometer do not work still... should i buy a speed sensor and try replacing the old one, even tho the old one still electrically tests as 'good'???
Current mods:
Short Ram Intake
Tint
8500K headlights
Old 11-29-2007, 06:45 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
What about the knock sensor?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 11-29-2007, 05:35 PM
Apparently the knock sensor code comes up all the time with old altimas; in addition, from what i know the knock sensor would not affect the functioning of the speedometer/odometer, it would just result in poor fuel economy.
Anyone know how to remove the instrument cluster?
Current mods:
Short Ram Intake
Tint
8500K headlights
Old 03-20-2008, 11:04 AM
Sypherz28 Sypherz28 is offline
Send a message via AIM to Sypherz28 Send a message via Yahoo to Sypherz28
please tell me you got somewhere with this issue cause i am having the same trouble just starting yesterday.. The speedo went out randomly, came back for about 20 mins that evening, then never came back again. however I havent had a code pop up of any kind as of yet.
1987 Mazda B2200
Old 03-22-2008, 08:41 PM
JoeShmoe's Avatar
Well the speedo, issue i don't know. I thought it was a mechanica device that could not go out unless disconnected from the chassy via one cable.
