| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
wideband questions
so im thinking about getting this wideband with the two outputs will it go to a gauge and to the ecu so i can log it with dsmlink?
http://www.slowboyracing.com/estore/...at=2439&page=1
1995 GSX 2Gb bumper Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5 /Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs ![]() Wish list: CAMS |
Re: wideband questions
Whether or not it works with a display depends on what they offer. I would check the main Innovative site and see what they have. I would assume that this is what the digital output (probably serial) is for. The LC1 does work with DSMlink, IIRC, you log it as the Techedge WBLinear.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
would i have to plug the output from the wideband into the laptop directly or can i log it through the ecu just using the obd port cuz i really dont need anymore cables in my car lol
You can log it through the ECU, is this is by far the recomended method. This way the WBO2 trace shows right up with all your other data and lays over it, to scale. Works the balls.
You'll end up wiring it into the rear O2 sensor input at the ECU most likely. You can also use the MDP sensor input, but I believe I usually put the MAP sensor on that now.
will it just plug in or do i have to create some wiring
It's not like Mitsu anticipated the developement of DSMlink and use of WBO2s, you'll be doing some wiring.
The good news though is that it is only one wire. If you are like me and don't like permanent changes, you can just splice/tee it in rather than chop up the harness, as long as you don't plug the rear O2 into the connector of course. You can get the pin/wire location from the vfaq's 2g ECU pinout diagram.
Hey I really want to stream My AEM EUEGO WB02 ratio into my rear 02 inlet for the ecu so I can log it. However I don't know which wires to solder up to it. Does anyone know?
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Run the analog output of the WBO2 to Pinout #75
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
thanks then how do you set it up with dsmlink so it gives you A/F ratios?
you have to find it under the captured values and make the ecu capture it then under values(f4) pull it over so it displays with all the other stuff
well I get the readings off my wbo2 from rearo2 but Im getting it in RAWvoltage only how can I get it so it shows a ratio:1 ?????
It has a specific name check under AEMuego (or something close to that)instead of rear02 under captured values
Probably AEMguage (or similar) since you have the guage type. There are 3 IIRC, and they are all different.
Ahh yes it is so simple now! Works perfectly thanks.
where did u solder your 12v switched power supply into?
