Old 06-25-2007, 04:22 PM
utzelu utzelu is offline
Bmw K100 cafe racer
Hi all,
This will be my first bike and, as usually with me, I have to modify it. I'm starting from a Tamiya BMW K100 and planning to turn into a cafe racer.
I have a question: do you know where can I get brass tube/rod of around 2.5 mm in diameter? I need to fabricate a new frame for the project and want to solder the sections, hence the brass material. Eventually even plastic rod will work.
See below for two photos of the bike in the current stage.
Old 06-26-2007, 01:24 AM
joelwideqvist joelwideqvist is offline
Re: Bmw K100 cafe racer
Great idea, will look interesting!
Regarding the rod/tube, plastic is most often found in your model shop and so is brass tube if the shop is well equipped. Otherwise take a look at the hard ware store.
/Joel
Old 06-26-2007, 01:45 AM
Well, I've ordered some plastic rod from Hiroboy's shop, so I'll try building the frame from plastic.
Other modifications I'm thinking to do on the bike:
+ rear side of the fuel tank to be reshaped using putty
+ seat to be scratchbuilt using putty
+ new clipons handlebars will sit under the upper tripple tree (if someone on this board can help me with lathe fabrication would be great)
Color scheme should be classic: gloss black with gold details (or stripes?) and planning to use Zero paints.
Any other ideas you can give are welcomed...
Thanks and Regards,
utzelu
http://scalemodelsadventures.blogspot.com
Old 06-26-2007, 02:24 AM
ketje's Avatar
ketje ketje is offline
Interesting built. Good luck with it.
Old 07-02-2007, 12:54 AM
Decided to rebuild the forks. So I cut the upper part and will replace it with metal tubing 3.5 mm.
Again, I need to find out an online shop where to get this tubing (I don't have any model shop around )
Thanks and Regards,
utzelu
Old 07-02-2007, 03:47 AM
I'm coming back for some information: what kind of metal should I use for the forks, in order to look as realistic as possible, without painting it? I think aluminium goes well after polishing. What about steel? Any other ideas?
Thanks and Regards,
utzelu
Old 09-06-2007, 02:32 PM
denman2's Avatar
denman2 denman2 is offline
you can just get a steel rod and polish it.
