1995 2.4L engine--Very High Idle
Hey guys
I have a 95 pickup with a 2.4 L. when i first crank it up in the mornings it will idle at about 750RPM for a very short time. as soon as rev up a little to back out of the driveway, the idle picks up to 1300RPM and stays that way from there on. also, if i crank it up when hot, it will idle at 750RPM for about 10 seconds and then works its way up to 1300 over an interval of about 20 seconds. it has been tuned up and i had to put a new timing chain on it (at only 100K miles..can you believe it!) the high idle is not related to the chain...it idled high before the replacement. i have also used the intake cleaner availabe at any parts store...that is, the direct spray method, not the kind you pour in you tank (though i have used that through the course of the life of the truck). any help is greatly appreciated. as with all of us, i am a little tight on money right now and i know this is burning a lot of extra gas. I have to do a lot of city driving. thanks again.
