Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-25-2007, 08:40 AM
violent31601's Avatar
violent31601 violent31601 is offline
Send a message via AIM to violent31601
Clutch Pops
hey guys,
I was wondering if you guys could steer me in the right direction or if you could tell me if this is a potentially big problem, or just minor.
So about my problem:
Everytime I push in my clutch it makes a "pop" noise, everything else works great (it doesn't slip out of gears and it shifts fine) it just makes a poping noise up by (what i think) is the firewall..
anyone have a clue?
thank you
Old 06-25-2007, 08:58 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Clutch Pops
Mine does the same sometimes. It's always if I push it down all the way, and start coming back up from it, it pops. Don't know what it is though.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-25-2007, 09:01 AM
Re: Clutch Pops
mine only does it when I push it down, and its only have way when it pops
Old 06-25-2007, 10:48 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Clutch Pops
Can you feel it in the pedal? Mine was doing that right after I bought the car and it turned out there is this stupid little thing under the dash that I needed to tighten. Is it a pop or an annoying clicking noise? It's been so long, I can't even remember what I did. I'll look around and see if I can find anything for you.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 06-25-2007, 10:54 AM
Re: Clutch Pops
its just an annoying click/pop half way through the process of pushing the clutch down
Old 06-25-2007, 12:00 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: Clutch Pops
check to make sure that the rod to the master cylinder isn't binding underneath the dash where it connects to the pedal... I had the problem once (different car)
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 06-26-2007, 08:03 AM
Re: Clutch Pops
Get under the dash and slowly push the clutch pedal down with the car off. If I remember correctly, my problem was the spring for the cruise control switch, or something stupid like that.
1997 Spyder GS-T
5-Speed
Old 06-26-2007, 08:17 AM
Re: Clutch Pops
if I push it in REALLY slow it doesn't do it, and what do you mean "cruise control switch" where is that located under the dash?
Old 06-26-2007, 06:57 PM
Re: Clutch Pops
It was the switch that disengages the cruise control whenever you push down on the clutch. Let me see if I can find a picture for you somewhere.
Here you go
1997 Spyder GS-T
5-Speed
Old 06-27-2007, 03:34 PM
Re: Clutch Pops
wow, I will see if i can find anything down there
thanks man!
Old 07-02-2007, 09:13 AM
Re: Clutch Pops
well, it turns out that all it need was some lube up by the master cylander...it was a bit dry up there!
thanks for the suggestions guys
Old 07-02-2007, 02:34 PM
Re: Clutch Pops
Well, I was close.
1997 Spyder GS-T
5-Speed
