Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-25-2007, 12:16 AM
speeddevil's Avatar
speeddevil speeddevil is offline
air sound?
well to my dismay i noticed while driving my caprice, i noticed and heard like the car sucking too much air. weird huh. its hard for me too explain but as a accelerate the higher i go before the trans shifts at 15 mph the engine sounds like its suckin lots of air, and as the faster i go the louder it sounds. i did check to see if the air filter cover and housing was mounted properly, which it was i could no find anything on what would cause this. anyone have any ideas on what it can be?
1987 Chevy Caprice LS 4.3L, 700R4 Trans.
Shaved Handles and Rear Deck.
Pearl Paint Job
Old 06-25-2007, 01:22 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: air sound?
Sounds like some kind of vacuum leak. If you're hearing it inside the car, then the chances are good that it's a vacuum line to the A/C control. There are a few vacuum motors under the dash that activate doors for the airflow, any one of those lines or the main supply line can be suspect. They're hard lines (plastic) which get brittle over time and can break.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-25-2007, 05:42 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: air sound?
If it sounds like an airplane taking off, check the fan clutch. It may be shot and coming on all the time. They're supposed to work only when the theromcouple inside tells it to.
Bob
Old 06-26-2007, 07:24 PM
speeddevil's Avatar
Re: air sound?
well the sound actually comes from underneath the car, right by the passenger side door, i did jack up the car and looked at all the exaust pipping and found no holes nor any leaks, would a busted catalyctic converter do such a sound as what i am experiencing with?
Pearl Paint Job
Old 06-27-2007, 05:49 AM
bobss396's Avatar
Re: air sound?
I think your cat is clogged up. Since the exhaust has got to go somewhere, it comes out the seams and you wind up with the loud hiss that you're hearing. If the car has over 75k miles and the cat is original, it is probably shot.
Look at the pipe off the manifold that feeds into it, which is part of the AIR system plumbing. Look over all the AIR tubing since they are prone to rotting out. The hose on the passenger side that comes off the AIR pump often rots where it meets up at the manifold tubing.
You can start the car up cold and quickly check for leaks by cupping your hand under suspect areas, you only have a few seconds before it gets too hot so take a good look first when the car is off and cool.
Bob
Old 07-14-2007, 11:38 AM
speeddevil's Avatar
Re: air sound?
i am gonna have to take a look at this simce i have not gotten a chance to look at it
Pearl Paint Job
