Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-25-2007, 12:04 AM
bigk4421 bigk4421 is offline
91 prelude
i have a 91 Prelude with a 2.1 and PGM-FI i use it as a race car and after about 6-7 laps when i step on the throttle the car starts to bounce really bad it doesnt do this before that it runs perfect. one guy found a hole in a vacuumm line that runs into what he thought was the speed sensor and he said that was the problem. could that be it or is that just part of it? it seems kind of weird any ideas or help? thanks
Old 09-23-2007, 11:01 AM
g2driver g2driver is offline
Re: 91 prelude
Well if a vaccume line is leaking thats ur first thing to fix for sure. Usually it'd idle bad too. But id fix vaccum line first.
Matt
Old 09-23-2007, 11:03 AM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Re: 91 prelude
vacuum leaks will cause the car to malfunction but there are no vacuum lines going to the speed sensor its either cable or electrical
Old 03-12-2008, 02:55 PM
ianwright07 ianwright07 is offline
Re: 91 prelude
if it was the vacum line it would do it all the time not after a few laps. unless it is for your evaporative emmisions canister and if its a race car thats just extra weight and wasted space take all that crap off and plug the vacum lines. if this is really just a race car there is little need for alot of little thigns i suggest losing. such as the fast idle solenoid and those blasted coolant lines that run thru the throttle body.
