Old 06-24-2007, 10:56 PM
minnesotatwins minnesotatwins is offline
97 high idle
On my 97 taurus gl with the 12v engine, it idles at about 1200-1250 rpm which seems pretty high to me. any ideas what could cause this or be the fix. Also when I put it into drive and take my foot off the gas it seems to go pretty fast, which I'm guessing is cause by the high idle. Thanks in advance!
Old 06-25-2007, 09:46 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 97 high idle
Either the idle speed control motor is hung, throttle plate otrgas pedal linkage is binding, or there is something that is holding the gas pedal down a little.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-25-2007, 12:50 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 97 high idle
Does it stay idling fast, or will the idle speed drop after it's been driven a few miles?
-Rod
Old 06-25-2007, 05:46 PM
Re: 97 high idle
-Rod
It stays idling fast even after the engine is warmed up and after driving.
Old 06-25-2007, 10:16 PM
shorod's Avatar
SHO No Mo
Re: 97 high idle
Then yep, I'd suggest you start with the items that way2old outlined.
If you said the idle slowed after time/temperature, I would have suggested starting with a bottle of fuel injector cleaner followed by a cleaning of the Mass Air Flow (MAF) sensor, and if that still didn't fix it, changing out the coolant temperature sensor.
-Rod
