Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-24-2007, 08:36 PM
fishmonster13 fishmonster13 is offline
97 rodeo chugging at low rpm
my 97 v6 rodeo is chugging mostly at low rpm seems to chug less with more throttle, i pulled the plugs they all look good did a compression test and that wad good , could use any suggestions
Old 06-24-2007, 08:41 PM
Ramblin Fever Ramblin Fever is offline
Re: 97 rodeo chugging at low rpm
Have you recently changed fuel filter? Picked up some bad gas maybe?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 06-25-2007, 06:40 AM
i'll check it , it's throwing a code check engine light is flashing , gonna take up to autozone and have them read the code
Old 06-25-2007, 07:35 AM
where is the fuel filter located at is easy to get to and check
Old 06-26-2007, 10:56 AM
tony4x4nc tony4x4nc is offline
Fuel filter is under the vehicle, passnger side....just in front of the rear tire along the frame.
Old 06-27-2007, 10:25 AM
all right changed fuel filter, no change cleaned egr no change so i took it up to autozone and had them read the codes , had a po302 misfire in #2 cylinder guy said it probably the spark plugs any one have similiar problem
Old 06-27-2007, 10:53 AM
surferfletch surferfletch is offline
Yes. Turned out to be the coil pack, but it was clear from looking at the plugs that #4 was wet and misfiring. If you haven't done the plugs in awhile, it'd be a good place to start.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 06-27-2007, 12:11 PM
i changed plugs about 6 months ago
Old 06-27-2007, 08:07 PM
problem was a bad coil found it after replacing the plugs and still had the misfire disconnected the coil on the cyclinder that was misfireing and no change
Old 06-27-2007, 11:40 PM
Beauty.
