air condition delete
i got a 94 caprice with a 350 engine....how much of a power gain could i get if i eliminated the air conditioning pulley?
Re: air condition delete
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
you would actually gain a couple but it wouldnt even be noticable, not worth the effort, especially if the ac still worked
Again, no power loss, not even 1 horsepower, by leaving in the AC compressor. The pulley acts as an idler when the AC is on, and while there might be a parasitic loss of power (on the order of a few percentage points of one HP), the amount of labor to remove the existing unit does not pay for itself over 10 years for the 'power' you will 'gain' by removing it.
If the bearing on the compressor took even one HP away from the engine, that thing would be frying belts left and right, smoking the whole time.
to add to this,
you wont gain much, if any hp, but you WILL loose a lot of weight, and you WILL gain more room in the front to install a larger radiator if you need it due to a 350 transplant. if weight is the enemy, remove as much of the ac components as possible and sell them on ebay or even better, bottle your refridgerant, and send it to me i need some... badly |
