Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-24-2007, 06:45 PM
tav tav is offline
please help
i have the toyota camry 93 , when start it s work about 10 minutes and then stop, i can' t start in this time and must wait 5 minutes more before i keep going on start my car can everybody help me solve this problem
ps i just replace the distributor , ECM , feul filter
Old 06-25-2007, 12:08 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: please help
Welcome to the forum. When it doesn't start, check for spark. You can use a timing light connected to any spark plug wire. If it flashes, you are getting spark. The wires, distributor, ignitor, and ECM are good. No timing light? Remove a plug wire, insert a screwdriver and touch it to the valve cover while cranking the engine.
If you see it spark, go on to check for fuel at the fuel rail. If there's no spark, come back here.
Crank the engine a few seconds then open the fuel test port on the fuel rail. If fuel squirts out you have plenty of fuel pressure from the pump. If it dribbles out or nothing comes out, you'll have to determine if the fuel pump is working. In that case come back here.
Read through the FAQs section at the top of the forum. Plenty of "won't start info there. You can download your factory manual at the "Factory Service Manual" thread.
We appreciate the fact you came here for help. Just next time please use a descriptive title for your subject line. "Please help" does little for someone searching the forum. "93 won't start" would have been better. Cheers!
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
