Old 06-24-2007, 06:42 PM
mr3000 mr3000 is offline
changing heads?
I was wondering if switching out my N/A head for vr4 heads/ cams would do anything for power, or are they the same?
Old 06-24-2007, 10:16 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: changing heads?
ehh, they would do a little bit for power, but unless you're doing a TT conversion, i would say its not worth it. if you really want some heads that flow better, get your NA heads ported and polished, or just get some of the staged heads that DR (dynamicracing.com) sells. they DO sell staged heads for the NA cars, even though its not listed on their site.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-25-2007, 01:15 AM
Re: changing heads?
yea i was thinking that porting and polishing them would probably be best, i just saw somw vr4 heads on ebay for alot cheaper than the cost of machining my heads now!
Old 06-25-2007, 11:13 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: changing heads?
VR4 heads will flow better than NA heads. As for the cams the intake cams are identical for NA and VR4. The NA exhaust cam is actually better than the VR4 exhaust cam
Old 06-26-2007, 12:12 AM
Re: changing heads?
ok, so do you think it would it be worth eventually buying some on ebay and changing the exhaust cams out?
Old 06-26-2007, 06:30 AM
Stealthee's Avatar
Re: changing heads?
Unless you plan on going balls out... no. THe gain wont be significant enough to make it worth it in my opinion.
Old 07-02-2007, 06:39 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
Re: changing heads?
hey..dont know what you ended up doing..buy i have an N/A and i had my heads port and polished..cost me 600$ from a local guy who does em..ide say it was worth it..cheapest horsepower that will always be there and you never gotta worry about it..
