97 Windstar Missing
I have a 97 Windstar that is running rough and missing. I replaced the plugs and wires and it is better but still not running right. I checked the resistance on the coil and it was 0.8 ohms.
This is within specs but could there still be a problem with the coil? How would I check for a blown head gasket? |
Re: 97 Windstar Missing
I suppose its possible its an intermittent coil. If your going to keep the vehicle you might want to change it out.
Have you ruled out a vacuum leak? Use a compression gauge to check for a blown head gasket.
'97 Windstar 164,XXX '99 Taurus 159,XXX S.E. Michigan |
Hello
I'll keep an eye open for it! Where was it last seen? JK To check for a blown headgasket one would have to do a conpression test. This would require pulling all of the plugs and using a conpression tester. Regards Dan
******************************************* Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK Photos of my repairs: http://dansautopictures.shutterfly.com/ Check this out:http://threewheelmotorcyclemetro.shutterfly.co A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854 95 Windstar 240,000+ 98 Windstar 136,000+ 09-25-2008. 85 Dodge 1 Ton Snow mover gas hog 91 Mazda Protege free beater SW MN |
