Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-24-2007, 05:22 PM
YooperInCO YooperInCO is offline
Firebird coolant leak
1995 Firebird 3.4L V6 leaking coolant from (as best as I can tell) behind the crankshaft pulley. Is this something that's fairly cheap to fix, or is it going to cost a second mortgage?
Old 06-25-2007, 12:11 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Firebird coolant leak
I would believe you're leaking from the water pump then, right above the crank.
Old 06-26-2007, 05:47 PM
Thanks.
Is it an easy or dificult fix?
Old 06-26-2007, 11:28 PM
sdsniper's Avatar
sdsniper sdsniper is offline
Originally Posted by YooperInCO
Thanks.
i had the same problem, i found out that one of those hoses were loose and i just tightened it and it stopped leaking. Might not be this, but check anyway.
Old 08-15-2007, 05:44 PM
rfsmith90 rfsmith90 is offline
check the weep hole, the hole on the bottom part of the water pump, if it is wet with coolant, the interior seal is bad and you need a new one... its medium level fix, i believe you have to remove the drivebelt and alot of brackets and stuff around it...
Old 08-15-2007, 09:04 PM
89Firebird2.8's Avatar
89Firebird2.8 89Firebird2.8 is offline
Best bet is water pump. Mine was doing that, but in my case both the water pump and hoses were bad. The seal was gone on my pump, so i changed it and it leaked less. Then i changed my hoses and that fixed it once and for all.
2012 Ford Fusion SE 3.0 V6
-SOLD- 1992 Lexus LS400 4.0L V8
-SOLD-1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.
