Old 06-24-2007, 02:04 PM
99oldsintrigue 99oldsintrigue is offline
Passenger doors will not unlock
I have a 1999 Intrigue and last week it developed a problem, the passenger doors will not unlock with either the key fob or the switch. The drivers door still works ok, and the passenger doors will lock, but they will not unlock - Any Ideas???
thanks for the help
Old 06-24-2007, 05:23 PM
Jimmy Olsen Jimmy Olsen is offline
Re: Passenger doors will not unlock
thanks for the help
Are you talking about using only the radio transmitter or also manually?
Old 06-24-2007, 05:50 PM
Both with the radio transmitter (key fob) and the lock/unlock switch on the door. I have tried both the drivers switch and the passenger switch, no difference. They still work if you push the little leverls by the door handle. I was thinking maybe there is a seperate relay?? I checked the fuses and didnt see anything to be out of order there.
Brad
Old 06-24-2007, 08:00 PM
Brad
I think that you are correct....there is a relay somewhere that is kaput. Hopefully, somebody here will know the answer. Otherwise, check out your local NAPA store and see what they come up with. The only other thing I can think of would be a bad connector.
Old 07-05-2007, 05:48 PM
Well guys I am getting there... I got a used BCM and installed it, the BCM was bad... now the car won't start Think I need the passlock fix
Brad
