Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 06-24-2007, 01:27 AM
laloquera laloquera is offline
1998 CRV Check Engine light
My check engine light keeps coming on and off for quite some time. I had mechanic hook up for codes. I don’t recall them, but It meant a miss fire in the #1 & #3 cylinder. He got me, the care runs great, traveled to Southern Cal putting on odometer more than 600 miles round trip from North Cali. Oooops & heading back next weekend. Want take care of this before it escalates to something much worse. Its my wife car and she’s (we are)three months pregnant. Its keeping up late at night guys. Anyone have a weird clarification for my engine light issue? Thanx
Laloquera runaround
Old 06-25-2007, 07:02 AM
jgr7 jgr7 is offline
Re: 1998 CRV Check Engine light
Have you had the valve adjusted? This is a very common issue whith this vintage C-RV. If it is not missing when cold you may have caught it before it burns the exhaust valves.
Jeff
Old 06-26-2007, 09:51 PM
candyguy99 candyguy99 is offline
I am also having the same problem with my 99 CR-V. I took it to Schuck's to diagnosis and a cyclinder #2 misfire was the fault code. The guy told me to replace the plugs, wire, cap and rotor. Is he correct? Thanks.
Old 06-27-2007, 10:23 AM
I don’t know about that! I've done all of the above with no result. The check engine light keeps coming on & off. The car has not stop running, its been a year & half since this issue started. I thinking of removing the dash and removing the check engine light bulb. Other than that the car runs great!
Laloquera
Old 06-27-2007, 11:01 AM
When my 98 started missing and threw the CEL with a #2 cyl misfire I took it to the dealer after doing the tuneup stuff. The dealer adjusted the valves and it ran fine after that. I now get the valves adjusted every 75K miles. The worst case is that if you don't get this done you will end up with burnt valves.
