Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-24-2007, 01:09 AM
totaleclipse1989 totaleclipse1989 is offline
Exclamation Zex Questions??
I recently purchased a zex nitrous kit...i have everything ran except for my TPS signaL WIRE...I DON'T KNOW WHICH WIRE OUT OF THE FOUR IS THE SIGNAL WIRE ON THE tps SENSOR...I ALSO WOULD LIKE TO KNOW WAT WOULD BE A SAFE SHOT ......AND DOES THE PURGE VALVE GO BETWEEN THE BOTTLE AND THE BOX..OR THE BOX AND THE NOZZLE.??
Old 06-25-2007, 08:18 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Zex Questions??
Um, I think you might want to check the operation of your "Caps Lock" key first, because it seems to be malfunctioning.
Also, what model / year vehicle are we dealing with?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 06-26-2007, 02:01 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Zex Questions??
Everything spyder said...
About the purge, I'm assuming the box is the solenoids, so the purge would have to go between the bottle and the box. What a safe shot is depends on what car you have and how appropriately you jet it, and how much timing you pull when it's active.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
