Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-24-2007, 12:52 AM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
porting
so im getting wicked boost creep how much does it cost to port my current o2 cuz im trying to buy a new one for 50-60 bucks is that how much porting would cost if anyone has a ported one sitting in their garage hit me up.
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 06-24-2007, 12:20 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: porting
Do work son! Porting really isnt too hard, if you have a die grinder and some patience. I think you can get 'er did in around a day or two depending on how extensive you port and how long you put in each day. IIRC, I had my o2 housing ported to hell, the turbo opened up a lot, head opened up and gasket matched, and exhaust mani gasket matched in about 15 hours of work. I have my o2 housing, but I sorta need it. I would for sure port yours for ya if you want. I can snap some pics and send them your way if you like. PM me if ya interested home boy.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-24-2007, 10:19 PM
Re: porting
so if all i wanted to was the o2 housing i would have to port the o2 housing itself and the gaskets on either side. i really dont feel like pulling the turbo out and porting that right now plus i have to drive it everyday so thats not really in the agenda. could i use just a regular drill or dremel tool with grinding bits?
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 06-24-2007, 10:40 PM
steviek's Avatar
steviek steviek is offline
Re: porting
no that would take you a month
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 06-24-2007, 11:34 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: porting
how much you want for a E316g port?
Old 06-25-2007, 12:12 AM
Thor06's Avatar
Jizzed In My Pants
Re: porting
Black99GST: Are you serious? I dont know that I would do a turbo again, atleast not with the bits I have now and especially not on someones good turbo. If you are talking about an Evo III o2 housing I could gasket match it if you wanted, but I cant imagine you would gain much from a full port on one of those.
cantgo2fast: Porting with a dremel would never happen, it would literally take you forever. No, you wouldnt need to port everything just because you did the 02 housing, and IIRC its usually the o2 sensor housing that is the culprit... not the manifold or the turbo. I'll shoot ya a PM.
Old 06-25-2007, 01:41 AM
Black99GST's Avatar
Re: porting
i already have a external dump o2 housing, and i dont boost creap at all... just was wondering what you would charge on the port job...
Old 06-25-2007, 02:00 AM
Thor06's Avatar
Jizzed In My Pants
Re: porting
Well, I guess I dont know... but in all honesty homie, I dont think I trust myself with your new turbo. To entertain your question, I guess I think I would ask $30 a port job for a o2 or a turbo.... I think?
Old 06-26-2007, 02:05 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: porting
Actually, the O2 housing has little to do with the boost creep on these smaller turbos. The turbine housing, or more accurately, the WG exit area, is the main problem. When porting the WG exit area however, you need to match the O2 housing entrance to the work done there, so they go hand in hand. Doing just the O2 housing does very little.
I've got a collection of old posts from 2002 or so on my site, here.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-26-2007, 02:39 AM
Re: porting
so i would need to do the wastegate first then the o2. it seems like most people solve their boost creep with just the o2 housing though. What kind if tools did u guys use to port yours? Ya after reading your posts i shouldve expected this because i have a full 3in exhaust with no cat it creeps to 22 psi @6600 rpm which is no good ive only run it that far once terrified of the consequences of going to redline because the creep probably wouldnt stop
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 06-26-2007, 02:54 AM
AF - Advisor
Re: porting
I should also add that you can port the turbine housing without taking the turbo off the car. Seperate the tubine housing at the vband clamp at the center section, and disconnect the downpipe and remove the 4 manifold bolts/nuts. When I was doing a ton of porting for the local group, I could go from starting work to actually grinding in about 10 minutes on most cars.
As far as tools, I use a 20 dollar pnuematic die grinder from HD or Lowes, and 2 or 3 carbide burs. Check www.mcmaster.com for a great selection. It would take a pretty special shop to find these things locally. Sometimes you can find a tool/die shop that supplies machine shops though in some cities... Great source for carbide burs, oddball drill bits and hardware, etc.
The vfaq talks about what you need to port on the turbine housing, with pics. I then match the gasket to my work on the turbine housing, which in turn makes an excellent template to make the O2 housing match. Do some blending and make it all nice, and ship it. It's not rocket surgery, just put a little thought into it and make it happen. I did it in steps since I was learning as I went, and had to go back in several times to get boost as low as I needed it to be back in the days before DSMlink and front mounts and all the other cool shit we have to run big boost on pump now. Don't be afraid to experiment.
Kevin Jewer
Old 06-26-2007, 02:57 AM
Re: porting
but if u do the wastegate exit do you have to get a ne flapper or do you just do the section after the flapper?
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 06-26-2007, 03:14 AM
Re: porting
where do you get your air from?
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 06-26-2007, 09:03 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: porting
An air compressor
95 Talon TSI AWD
97 Eclipse GST
Old 06-26-2007, 02:53 PM
Re: porting
yes but a really big air compressor like for shop air or one thats not nearly as big cuz i have one of those
1995 GSX 2Gb bumper
Wish list:
CAMS
