Old 06-23-2007, 11:08 PM
X2Xtreme360 X2Xtreme360 is offline
strange, inconsistent problem
Sometimes when I bring the car to a stop and it idles foe a few seconds, when I take off again I see a puff of white smoke. It seems to be more consistent when putting the car in reverse and gassing it, but it's not consistent. It's not a stream of smoke either, it's just a puff, then it stops. Is this something I should be worried about? It doesn't happen all the time.
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 06-24-2007, 01:05 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: strange, inconsistent problem
valve seals.
Old 06-24-2007, 01:30 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Originally Posted by Stealthee
valve seals.
u sure? i thought worn VSS would be indicated by blue smoke = burning oil. white smoke usually indicates burning coolant.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-24-2007, 02:26 AM
Stealthee's Avatar
People mistake valve seal smoke for being white ALOT. The symptoms he describes are valve seals. If he was burning coolant it would be doing it all the time. On top of that I have heard of a total of maybe 3 3s's in 5 years of being around that have had blown headgaskets. Its not a common issue.
Old 06-24-2007, 04:11 AM
Linebckr49's Avatar
true, the symptoms are indicative of valve seals.
QFT about the head gaskets. i once overheated my engine 3 times in 1 hr (construction zone on highway, no shoulder either side, could not stop to let it cool down, had to go to next exit) trying to get her home. i went WAY into the red, and it stayed there for about 10 minutes each time. leakdown, compression tests all great. head gaskets perfect, just needed a new thermostat.
93 3000GT base
Old 06-24-2007, 11:22 AM
would this be something that needs to get fixed right away? I wouldnt want to hurt the car.
Current mods:
Cold air intake
Polished Plenum
Old 06-24-2007, 12:00 PM
Stealthee's Avatar
NO several people run with leaky valve seals for extended periods of time with no ill effects. Just make sure to keep an eye on the oil level.
Old 06-24-2007, 01:29 PM
Linebckr49's Avatar
ya, its fine. its basically a small oil leak, but you leak oil from the valve cover into the combustion chamber, and its burned off. so periodically check your oil level.
i would wait to change your Valve stem seals (aka VSS) until you change your timing belt next, b/c it will require you to remove the camshafts.
93 3000GT base
