Old 06-23-2007, 09:52 PM
lucas_wojo lucas_wojo is offline
Red face blower only works on high
I have a 98 intrigue that has the 3.8 and the blower only works on high. It still blows AC and heat but none of the other fan settings work. What do i need to replace? I was told it was a realay, then somone said it was a resistor in the blower motor, then i was told to just replace the whole blower motor assy. Well, i am not going to throw parts at it, Any ideas? The blower motor seemed like it was a sealed one piece unit, if it were a resistor how would i change it? Or how do i fix what ever the problem is? Please help [email protected] Thanks
Old 06-24-2007, 08:19 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: blower only works on high
Ive seen this problem on here before, and the typical fix seems to be the blower motor resistor, Im unsure of the procedure and parts cost, but if you do some searching around on here for resistor you should find some good information.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 06-24-2007, 01:57 PM
Red face Re: blower only works on high
I will do that. THANKS
Old 07-26-2007, 01:22 PM
rncotton rncotton is offline
Blower motor resistor pack is about $25 at NAPA. The pack is located behind the dash. Pull the center vents and find a contortionist with small hands.
Trust me.
Old 07-26-2007, 01:44 PM
burijon's Avatar
burijon burijon is offline
http://www.rockauto.com/catalog/x,ca...,parttype,6557
This will at least give you an idea of what it looks like.
2005 Acura MDX 85k
2004 Acura TSX 96k
Previous 2000 Intrigue head gaskets death
