Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-23-2007, 06:47 PM
abner660 abner660 is offline
impala keeps quititng
im working on a 2000 impala with just over a 100k and its got 2 codes being P0410 and p0412 secondary air system switching valve A seems to be the problem how do i go about fixing this. Where is this vavle on this car it has the 3.8 L
Old 07-16-2007, 02:24 PM
onestep onestep is offline
Re: impala keeps quititng
dude i got to load my mitchell and ill have a look here after a while i had to reformat my pc and ittl take awhile ill check back later
Old 07-17-2007, 04:04 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The codes you have refer to the secondary air injection system. You live in a green state (NY) so your car has extra emissions pieces that most states don't require. The A.I.R. pump is located in the left front fender area just forward of the wheel well, and is prone to water intrusion. The water corrodes up the internals of the pump and it locks up. The codes you have are common for this problem. Replacing the pump is the solution, as they are a sealed unit and cannot be repaired. The AC-Delco part number is 215-414 (GM #12568241). There is a GM service bulletin (04-06-04-037) that addresses this issue. It suggests fabricating a shield to help deflect the water that comes from the wheel well away from the A.I.R pump.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
