Old 06-23-2007, 06:42 PM
DeadBlade89's Avatar
DeadBlade89 DeadBlade89 is offline
Send a message via AIM to DeadBlade89
O2 Sensor
My O2 sensor is too short for my new header. How should I go along in making it long enough? Can I just cut the wires and add some to make it longer or wont that work? Thx
2000 Pontiac Sunfire SE
Originally Posted by freakray
You're right, I actually own a '94 Civic, I just put Subaru badges on it and make the turbo noises as I drive down the road to fool other people.
Old 06-23-2007, 08:34 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: O2 Sensor
Yep, pacesetter's come with new wire to lengthen them. Just make sure you cut properly. Cut in between the sensor and the clip. Not in between clip and PCM
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 06-23-2007, 11:09 PM
Re: O2 Sensor
ok, thx cody. so its just normal old wire, nothing special about it like a resistor wire?
Old 06-24-2007, 02:28 PM
Lifted GMT-360!
Re: O2 Sensor
Nope, its either 18 or 16 gauge wire.
Old 06-24-2007, 02:29 PM
Lifted GMT-360!
Re: O2 Sensor
oh, make sure you solder the connections and use heat shrink over black tape. The sensors are prone to getting hit with water since they are soo low.
Old 06-24-2007, 04:47 PM
Re: O2 Sensor
ok, thx alot cody
Old 07-05-2007, 11:26 AM
Blue Bowtie's Avatar
Registered Offender
Re: O2 Sensor
The confusion over whether or not to splice likely stems from the earlier O² sensor which used their hollow wire as a supply for reference air at the zirconia element junction. This scheme was mostly abandoned by the late 1980s, and a reference air supply vent was provided in the sensor body. Improperly crimping or soldering the leads on early style O² sensors could block the supply of reference air and render the sensor useless (permanently rich) to the control system. You should be able to safely extend the length of any lead in the O² sensor circuit on later vehicles or those which have had the sensors replaced with a later, more modern style.
Old 07-05-2007, 04:10 PM
Lifted GMT-360!
Re: O2 Sensor
Originally Posted by Blue Bowtie
The confusion over whether or not to splice likely stems from the earlier OČ sensor which used their hollow wire as a supply for reference air at the zirconia element junction. This scheme was mostly abandoned by the late 1980s, and a reference air supply vent was provided in the sensor body. Improperly crimping or soldering the leads on early style OČ sensors could block the supply of reference air and render the sensor useless (permanently rich) to the control system. You should be able to safely extend the length of any lead in the OČ sensor circuit on later vehicles or those which have had the sensors replaced with a later, more modern style.
Relivance?
