Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-31-2002, 10:31 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Exclamation Will a s-15 sr20det motor wit 6-speed motor fit into a 96-up 240sx
please help
s15 motor wit 6speed tranny will it fit into a 96-up 240sx
Old 11-05-2002, 05:59 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
yes
Old 01-07-2003, 11:36 PM
sephalix sephalix is offline
Send a message via AIM to sephalix
it wil fit but the tranny is weak, so you might want to use an S14 tranny with the S15 engine. but the S15 engine has no real advantages over the S14 or even S13 motor except for bragging rights. the S15 SR20DET is about twice as expensive to build up than the S14.
why that's...BIZZARO!!!
Old 01-08-2003, 08:19 AM
turbo2nr's Avatar
umm... what about the 241hp from the factroy as opposed to the 205 of the s-13 red top, also the s-15 has a better turbo desing , i think it uses sum form of a ball bearing setup also the six-sp tranny, not 2 mention the vvt system, but other then that yea no real advantages!
1
Shift_BOOST
97 s14
Old 01-09-2003, 01:51 AM
if you plan on tuning the engine anyway it really doesn't matter. the S13 SRs have a bigger port and most race engines get rid of the VVT anyway. 205 vs. 241 isn't really much of a difference considering the S13 SR has 203ft-lb. torque and the S15 has 202ft.-lb. so if you are keepint it stock, go for it i guess, but if you are going to tune it, the earlier SRs are a better bet because they are cheaper to tune and an S13 SR20DET will easily match a similarly tuned S15 SR20DET for less money. iv'e seen it. i was window shopping for S15 motors when i foudn all this out, my choice is now a blacktop S13 SR20DET. but good luck with your project whatever you decide. SRs are great motors.
Old 01-09-2003, 08:03 AM
turbo2nr's Avatar
thanks!
but i will go wid da s-13 sr20det cause im still gona tune it so the vvt will jus get in my way, also i will upgrade the turbo so the 1 in da s-15 will still me a waste also the 5g's u spend 4 da s-15 sr20det i will have the s-13 sr20det swaped into a 240sx with minor mods!
thanks for ur input
1
Shift_BOOST
97 s14
Old 01-09-2003, 12:33 PM
hey np man, good luck with your project!
Old 05-05-2003, 06:09 PM
Drewama Drewama is offline
Lightbulb
Check out Import Racer Magazine and Drifting Magaize, Lots of helpful advice!
Old 05-05-2003, 11:02 PM
Suislide's Avatar
Suislide Suislide is offline
advertising on AF is not allowed. you know that, right?
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
Old 05-06-2003, 12:27 PM
CAptynCrunch CAptynCrunch is offline
Dragging up five month old threads is also frowned apon.
Keiichi Tsuchiya isn't the drift king,
Michael Schumacher Is.
The only thing better than cars is Music... maybe.
Old 05-06-2003, 02:34 PM
S14Kyle's Avatar
S14Kyle S14Kyle is offline
Send a message via AIM to S14Kyle
Why has there been a recent outbreak in the 240SX and Silvia forums in bringing back threads from the dead?!
I <3 Nissan
Yo, yo, yo, pimp juice. I've got the bling bling hookup, biatch.
Old 07-05-2003, 09:02 PM
Schramproff108 Schramproff108 is offline
Check out this site: www.heavythrottle.com
They'll help you out with everything you need for the swap including the engine, mods, etc. and they're located only two hours away from you in Poughkeepsie
Old 07-07-2003, 08:58 AM
turbo2nr's Avatar
wow this thread is old..
1
Shift_BOOST
97 s14
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
