Old 06-23-2007, 12:47 AM
russ_95670 russ_95670 is offline
91 vr4 3000gt
i just sold my lt1 trans am and bought a 91 vr4 and its awsome,i got it for really cheap and i need to perform some repairs on it, anyways, the pass front wheel makes a clunking noise when i go over cracks in road and bumps ect, wheels are on tight and axels appear fine, any suggestions like struts or what ever these things have up front ? and second on that whole recall on transfer case, how do i know if it was performed and if it wasnt will the dealership fix it for free?
thanks.
Old 06-23-2007, 11:37 AM
new2mitsu new2mitsu is offline
Re: 91 vr4 3000gt
kno yer vin? couplea ppl here could check it for you
Old 06-23-2007, 11:38 AM
Re: 91 vr4 3000gt
good choice by the way. pontiac to mitsu is a step up in the world :P
Old 06-23-2007, 07:53 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 91 vr4 3000gt
found a cheap VR4, huh? tell us a little more about it.
miles?
color?
pics?
price?
maintenance?
check out the FAQ thread for some good info. easiest way to find if recall has been done is to call a dealership and give them your VIN. do a search for the Recall, many threads about it. you'll learn quickly (if you haven't already) that these DOHC imports are much more complicated and a lot different from american OHV V8s. i highly suggest you get a service manual (can either get the book version for $$$ or get a manual on cd off ebay for a mere $20) before attempting any engine work like the timing belt. and before you start with the performance mods for the engine (upping boost, bigger injectors, etc etc) i suggest you look into getting a datalogger. there's a post in the FAQ (page 2 at bottom) about them.
welcome to AF!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-23-2007, 08:20 PM
quackmandude quackmandude is offline
Re: 91 vr4 3000gt
the clunking noise could be a lot of things, does it do it only at a certain speed? i could be alignment, doubt it tho. tie rod end, strut ill even go as far to say rack and pinion, cuz thats one of the symptoms my sl has right now and the rack and pinos messed up.
'94 3kgt SL
-ebay intake (why not)
-2 1/2 inch straight pipe exaust, custom y downpipe
-Ignition mods
-dual magnaflow exaust
-going TT (wish me luck)
black book
-'95 mustang v6 (modded) /////
-'00 neon (modded/non-turbo) ///
-'04 eclipse GT
-'05 eclipse GT (modded)
-'97 Prelude vtec (modded)
-CRX (modded)
-Mazda Miata mx5 //
Old 06-23-2007, 10:19 PM
Re: 91 vr4 3000gt
2500$
108,000 miles
its like a gun metal more of a dark silver
not much on maintence
Old 06-24-2007, 01:06 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 91 vr4 3000gt
You bastard. Thats Sandstone Grey Metallic. Freakin awesome color.
Old 06-24-2007, 08:33 PM
AutostradaVR4 AutostradaVR4 is offline
Re: 91 vr4 3000gt
seriously. throw some pics up in the pics thread.
for the clunk, my bet is on struts.
when you bought it, did the seller mention anything about the 60k maintenence? when the last time the timing belt/pump were replaced?
definitely read the FAQs. welcome to AF
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
