Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 06-22-2007, 07:13 PM
userpete1037 userpete1037 is offline
Leaking Antifeeze.....
I have a 97 Deville and it's leaking antifreeze sparingly. I can't see where it's coming from. i've checked the hoses and none of them are leaking. What i do know is that it's coming from the side where the water pump is. i'm thinking it's the pump but it's not leaking enough for me to tell..Looking for answers.
Old 06-24-2007, 07:18 AM
DFBonnett DFBonnett is offline
Re: Leaking Antifeeze.....
Your best course of action is to put a pressure tester on the sytem then carefully go over every possible leak source.
Old 06-26-2007, 10:17 AM
caddydaddy caddydaddy is offline
When the water pump on a Northstar does leak, it leaks very slowly. If you can't see it, I also suggest the pressure test.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 07-30-2007, 08:10 AM
It's been a month and i replaced the water pump. So far i've seen no signs of leakage so i guess that did the trick. However, it was a pain getting off.
THX
