Old 06-22-2007, 06:10 PM
oz153 oz153 is offline
2001 oldsmobile intrigue 3.5
hello
overheating probleming removed t state and i have good flow threw. when the cap is off seems not to over heat but when cap is on it heats up quick. also at 4000 rpm it drops out like plusing any ideas
Old 06-23-2007, 12:59 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: 2001 oldsmobile intrigue 3.5
Have you tried replacing the thermostat with a new one?
If your reaching 4000 rpms in either Park or Neutral the engine is doing exactly what its supposed to. It wont rev higher than 4000 rpms in those situations.
Or are you talking about the engine begins to run rough after 4000 rpms?
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 06-24-2007, 10:00 PM
atoyota4x4 atoyota4x4 is offline
If you figure out the overheating issue, let me know. Mine has been doing it since this past winter. Would always do it on very cold days, below freezing. Now its doing it when its really hot out, 85 and above. Between those times, not problems. I tried 2 t-stats and everything else I could thing of. Very strange problem these 3.5L have and NO ONE can give me and answer to what is causing this. There is never a rhyme or reason because sometimes when its hot out, it runs normal. Sometimes having the AC on causes it to get hot, then the next time it makes no difference. I have had it to the GM dealer and to a cooling specialist and neither could get it to overheat. It just was one of those days when it decided to act normal. Its like they know when the mechanic is looking them over. Very frustrating
I told my wife, drive it until it blows up or until I can find a cure.
Old 07-28-2007, 07:44 PM
rzb1992 rzb1992 is offline
hi, I just got a 01 Intrigue, and it has a little over 93,000 miles. the transmission was just rebuilt last year, and now the engine is making a sort of loud knocking noise, but only when you hit the accelerater. (if it's idiling, it's fine). I have a feeling that I will need to replace the engine, but 1) does anyone have an idea of something else that could be causing it where I might not have to replace the engine? 2) does anyone know of an easier way to change the engine besides the large thourough process of taking the whole front end out? thanks
Old 02-04-2011, 08:50 AM
monsterman7888 monsterman7888 is offline
My oldsmobile intrigue was running fine but then the service engine soon light soon started flashing it smells like sulfur the smell you would get from like a fire work thats went off and idles slow
Old 02-04-2011, 07:56 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Originally Posted by krivasauto View Post
Please do not resurrect three year old threads. Start a new one. Please do not reply to this thread.
Not a problem. We no longer have any rules prohibiting resurrection of old threads as long as it is not way off topic and the member needs help. However, whenever possible it is a better idea to start a new thread.
Timeslip 08/12/06
AF Community Guidelines
Old 02-06-2011, 06:56 AM
panzer dragoon panzer dragoon is offline
You can buy a dandy OBD2 reader for $60-100, plug it in and read those codes. I like the Sears Craftsman one for $90 with the DVD and computer cable. Autoparts stores will OBD2 scan you for free -but I would call ahead to check first.
Sounds like a catalytic.
