Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 06-22-2007, 01:01 PM
tempfixit tempfixit is offline
94 villager headlight problem
The passenger side headlight does not work on low or high beam. I have replaced bulb and it worked for a short period of time, since it is not working again I switched it to the driver side and bulb works on that side. I am thinking bad connection at dimmer switch (High beam light stays on whether on low or high beam, driver side does switch from low beam to high beam)
Can I use contact cleaner on the dimmer switch without removing it?? The headlight switch is on the dash left side. I have checked for power at the light socket but have none.
Thanks for advice
Old 06-23-2007, 10:09 PM
IH8SPM's Avatar
IH8SPM IH8SPM is offline
Re: 94 villager headlight problem
This problem is common and we have discussed it before. Please search the forum for the answer to avoid mutiple postings. Thanks
