Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-22-2007, 02:20 AM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
Low Oil Light
I think I've posted this before....around a year or so ago I believe...someone told me that the light would eventually just stay on all the time, however:
I start the car, the Low Oil light is on, shut the car off, start it back up within 10-20 minutes, and the Low Oil light is no longer on. I'm thinking it might be a lose connection or something of the sort. Where is the Oil Sensor located under the engine bay? Engine is not low on oil, and it has never burned a lick of oil.
Also, is it possible to clean an ABS Speed Sensor, or would it just be easiest to replace it altogether?
1995 3.4 V6 MFI runaround
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 06-22-2007, 10:02 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Low Oil Light
I believe the oil sensor is toward the center of the pan on yours? If not, look around the fitting where the oil filter goes.
And yes, you can use a can compressed air for keyboards to blow the debris out of it and the reluctor ring and attempt to clean it.
