Old 06-21-2007, 10:54 PM
dhrubio's Avatar
dhrubio dhrubio is offline
Send a message via AIM to dhrubio
logger?!
quick easy question: is my 94 fed spec 3kgt a hydrid between obd1 and obd2? thanks
(im close to getting a logger but the guy just informed me his loggers dont work for hydrids...)
Old 06-22-2007, 06:44 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: logger?!
Yes 94 and 95 3s's are hybrids.
Old 06-22-2007, 01:52 PM
dhrubio's Avatar
Re: logger?!
ok, i wasnt sure because i was checking around on some sites and it actually says that MOST 94-95s were hybrid, but like always theres exceptions so make sure.....so how can we really check to be sure?
Old 06-22-2007, 02:01 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: logger?!
i just added more info to my post in the FAQ (page 2, last post) about Dataloggers. check it out.
however, that IS a good question you have: how to tell by inspection that your car is a 94-95 hybrid ECU. first of all, i would just check by the build date of your car, but this can be confusing. i'd bet there is something different about the diagnostic connector, but i don't know for sure.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-22-2007, 02:30 PM
dhrubio's Avatar
Re: logger?!
wow very informative thread you have there....thanks for trying to help, im going to keep researching and see if i can figure out the deal on the hydrids
Old 06-22-2007, 03:32 PM
dhrubio's Avatar
Re: logger?!
alright, so basically with my 94 im sort of shit out of luck, because my only option is the miragecorp for $250, correct? although the HHH looks pretty good, which in US is $107? looks like that HHH deal comes with cables and software, so i would just need the palm or laptop? could i use my phone? it looks like the HHH package is compatible wit usb for laptops, so if i download the software into my laptop, could i then transfer the software into my phone via phone-usb cable i have?
p.s. that last sentence of the third paragraph on the HHH site is what bothers me...grrrrr
Old 06-22-2007, 04:12 PM
Linebckr49's Avatar
Re: logger?!
here are some useful threads. the topic of one says "OBDI, OBDII, OBDII Hybrid".
http://www.3si.org/forum/showthread.php?t=367003
http://www.3si.org/forum/showthread.php?t=364837
93 3000GT base
