Old 06-21-2007, 08:07 PM
hossbigs hossbigs is offline
92 Civic DX SRS light on after clock spring snafu...
Hello all,
...got a 92 Honda Civic DX Sedan.
A friend replaced my combo switch a few months back and after that, every time I turned the wheel all the way left, you could hear the clock spring grind. After about a week, the SRS light was intermittent, after another week or so, it was on all the time. I subsequently learned about how to R/R the steering wheel correctly myself. So I took it off and put it on correct....grinding noise gone...SRS light still on. So I figure the cable on the clock spring is hosed.
Got a replacement clock spring from salvage yard ($10)...plan to install tomorrow.
Will it be necessary to reset the SRS light after the install?? I've read all over the net about how to reset the SRS light on Civic's with the connector by the fuse box...and I've actually seen that connector in a 95 EX and I think a 93 LX (yellow connector in dummy housing in drivers side fuse box)....however, I don't have that connector on my 92, so I'm not sure where to do the reset? Or is it possible that the 92 doesn't have a reset that I can jumper or needs some other procedure?
Thanks in advance for any advice....
KJ
Old 06-22-2007, 08:35 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: 92 Civic DX SRS light on after clock spring snafu...
you could just disconnect your battery for 10 mins... that will reset everything, ECU, SRS ECU.. etc.
Old 06-22-2007, 08:14 PM
Well I put in the new clock spring today, and the battery was disconnected while I was working. It went in great and the SRS light doesn't stay on now. I actually pulled the old clock spring apart and was able to see the break in it.
Next, I get to deal with an intermittent CEL code 8 - TCD sensor. I'll put that one in a new thread sometime soon.
Thanks,
KJ
Old 07-01-2007, 06:14 PM
symph0ny symph0ny is offline
I messed up the SRS system while changing some fuses. I found a guide googling, and it worked great. Used aligator clips and a piece of speaker wire.
Here's the guide, good luck
http://www.geocities.com/myintegra96/srs.html
