Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-21-2007, 06:41 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Thinkin I got a boost leak.
Anyways before I go to the trouble of making a boost leak tester...which I'll probably do anyway, I just want your guys input. Anyways sometimes when I take off...I don't have to give it alot of gas....but it will cruise fine then out of freakin nowhere it will start jumping...kinda like if a boost pipe fell off...which makes me think its a boost leak. It does the same thing sometimes when I'm cruising and give it the gas. It only does this for a few seconds then straightens out. The check engine light also comes on for like 5 seconds....not long enough for me to check it. Also when its idling it doesnt hold a constant idle...it moves up and down by like 100 rpm veriations. Also when I'm parked and rev it to any given rpm, lets just say 2000....it wont hold at 2000rpms....it jumps up and down some like lets say 1950-2100 or so...just wont stay at 2000. I'm still new to this turbo crap, so any help will be appreciated greatly. Thanks again.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 06-21-2007, 07:12 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Thinkin I got a boost leak.
That idle seems fine to me. Mine always in that range. Goes from 750 - 950 at idle. It's work trying out to test it all out and see where leaks are. But I personally think the idle is fine.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-21-2007, 07:44 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
I dont know if it would be a boost leak if the problem just kind of goes away...I would probably get worse with the higher boost that you are getting...but its not a bad idea to make a tester...it definitely makes it easier to find.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 06-22-2007, 06:56 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Although the ECU may turn the CEL off, it will still retain the DTC until it looses power. I would try and pull the code.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 06-22-2007, 09:31 AM
I tried that but it said that there are no stored codes.
Caleb
vanilla gorilla
Old 06-22-2007, 11:59 PM
Well I made a boost leak tester tonight so tomorrow I'ma try it out and see what happens.
Caleb
vanilla gorilla
Old 06-27-2007, 04:47 PM
boostedjess boostedjess is offline
Most of the time if you have a boost leak, it makes a noise, like a paper bag or a crinkling noise sort of.. I think I have one at the moment, but I'm going to use a tester to see.. I have a 1g so my lines and hoses are pretty old and need to be replaced ASAP anyhow.
And your idle is fine.. typical usually.. I have a rough idle at time, but it's a DSM..
