Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 06-21-2007, 07:13 PM
topsecretagentx topsecretagentx is offline
Question Help! 94 Marqui Stuck in park
My pristine 94 Marqui is stuck in park. It starts fine, sounds good, but the shift lever will not move. There are no engine or warning lights on, and I have allready disconnected the battery to try and reset any sensors. Any ideas out there?
Old 06-21-2007, 08:17 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Help! 94 Marqui Stuck in park
Do you have brake lights?? If there are no brake lights on the back of vehicle, look for blown fuse first, then check brake light switch. HE Connector on switch will also break.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-22-2007, 06:17 PM
Question Re: Help! 94 Marqui Stuck in park
brake lights are not working, and i have checked all the fuses. What the heck is an HE connector? And where do I find it?
Old 06-22-2007, 07:09 PM
way2old's Avatar
TOKEN HILLBILLY
Sorry about that. I meant to say the switch. I am talking about the brake light switch that is located on the brake pedal. If you lay under the dash and follow the brake pedal up under the dash, you will see the brake light switch. Removing the lower panel may give you more access to get to the switch. Good luck. Here are a little more detailed instructions on replacement. I don't have a picture guide.
Old 06-23-2007, 08:34 AM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
You should be able to move the car (if you have to) by turning the key one position then the shifter will move to N where you can start it and then put it in D. The actual directions are in your owners manual. (I had to look it up when my 98 did it) . BTW, mine would blow a fuse every time you stepped on the brake. It turned out to be a bad ground.
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold)
HIS----> 2003 Dodge 1500 HEMI QC 4X4
Old 07-08-2007, 05:52 PM
strangerinthemidst strangerinthemidst is offline
Send a message via AIM to strangerinthemidst Send a message via Yahoo to strangerinthemidst
I had this problem on Friday.
Turn the car off, turn the key to the first position (the dash will NOT light up in this position) put the car in N and start the car.
It was just the fuse for my brake lights. $2.99
