Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-21-2007, 05:45 PM
playboiij playboiij is offline
Why is my chevy running hot?!?
I got a 93 caprice and i cant figure out why it is running hot. It is full of aintifreeze so what could be the problem?
Old 06-21-2007, 06:00 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Why is my chevy running hot?!?
Plugged catalytic converter, bad thermostat, other exhaust restriction, coolant flow restriction (collapsed hose, plugged radiator etc), loose drive belt, bad fan clutch or electric fan, any number of reasons, really.
You can determine an exhaust restriction by placing a vacuum gauge on the engine and starting it. A restriction in the exhaust will show by a normal reading that tapers off to a very low vacuum reading.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-21-2007, 06:20 PM
how serious is it?
Old 06-21-2007, 06:43 PM
silicon212's Avatar
Confoundingly Lucid
How serious is it? If you have money to burn and time to waste, it's not serious at all. However, if you want your engine to live, and not strand you in the middle of BFE, it's very serious.
Old 06-22-2007, 05:55 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
I've been to BFE, not a pretty place after dark that's 4 sure. If the car quits on you and it smells like an overheated waffle iron, get your cell phone out and call a wrecker.
Some of the things silicon came up with are easy to diagnose. If you're not that car saavy, have a pro look at it.
Bob
Old 12-01-2007, 04:44 PM
blackEyeSSFly blackEyeSSFly is offline
I would check the thermostat first...thats the most simple problem that it could be....
does it get hot as soon as you start driving...i had similar problem and it turned out to be the thermostat...i order mines off the impalass website...takes about 10-20 minutes to install..
Cardomain http://www.cardomain.com/ride/2143750
Success is to be measured not so much by the position that one has reached in life as by the obstacles which he has overcome
Old 12-01-2007, 06:15 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
You can just go to ANY local auto parts store and get one, small block chevy thermostats are a very common part for parts stores to stock.
Old 12-02-2007, 02:22 AM
yea your are right...
i just order most of my parts from http://www.impalasuperstore.com or summitt
