Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-21-2007, 11:39 AM
musclecarfan6's Avatar
musclecarfan6 musclecarfan6 is offline
speed limiter
I have a 95 neon with a SOHC engine. How do I get rid of the speed limiter.
95 Plymouth Neon 2Door 2.0L SOHC
89 Buick Century Custom 3.3L
____________________________
What to see pics of my cars. Go
to www.cardomain.com and look
for musclecarfan6. Rate or leave
comments if you want.
Old 06-21-2007, 08:57 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: speed limiter
Buy a 95 ACR PCM (no speed limiter) or unplug the speed sensor (but then you can't tell how fast you are going).
2003 Dodge SRT-4
Old 06-21-2007, 09:25 PM
Re: speed limiter
what are the numbers on an acr computer. On the car or the unit.
Old 06-22-2007, 12:54 PM
Bear Bear is offline
Re: speed limiter
Actually the MOPAR PCM limits at 148 MPH, the ACR/RT PCM limits at 130 MPH, and the AF/X PCM has no limit. Stock PCM is limited to 118 MPH.
Old 06-24-2007, 12:37 PM
Re: speed limiter
What are the numbers for a AF/X pcm. Where can I get a mopor pcm.
Old 06-24-2007, 09:31 PM
Re: speed limiter
The MOAPR performance PCM MAY still be abvailiable from a dealer, if not then try Neons.org, Modern Performance, EBay. The AF/X came in two versions, street and strip with the strip version offering a bit more power, the down side was you had to provide them with your PCM in oder to buy theirs. I will dig some data on on these two products and post tomorrow.
Old 06-25-2007, 07:32 AM
Re: speed limiter
I do not have figures for the SOHC, but for the DOHC, the MOPAR PCM produces 138.6 HP@6500 RPM/the AF/X street 141.8@6500 nd the stock ACR 131.2@7000 RPM (these are dynomometer readings), do not confuse them with the sales literature readings as these compensate for any power loss through the clutch and drive axles). Best 1/4 mile readings were:
Stock [email protected] MPH
MOPAR [email protected]
AF/[email protected].
You can buy these products at howellautomtive, modernperformance, maybe EBay and you might find a used one at neons.org.
Good luck
Old 06-25-2007, 10:10 PM
Re: speed limiter
thank you very much.
