Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-21-2007, 10:30 AM
BeZerK2112's Avatar
BeZerK2112 BeZerK2112 is offline
380HP Isn't Enough...
Maxima Codes
Can a 95-99 maxima have a problem without indication? Can I take it to auto zone and have it pluged in to see if there is anything wrong or would I get a check engine light if there was something wrong. I've been noticing a serious reduction in fuel economy just recently and am wondering if the knock or o2 sensor can go out without warning.
WHAT KEEP IT STOCK! Well that takes the fun out of it.
[center]
99 Maxima - View the Project at CarDomain
Old 06-21-2007, 01:55 PM
rather_b_boatin rather_b_boatin is offline
Re: Maxima Codes
Autozone can only read it if you have a CEL light on. Air filter, fuel filter, plugs and go from there.
Old 06-21-2007, 02:45 PM
discnik discnik is offline
Re: Maxima Codes
There are certain problems that can occur and put a code in your computer and not trigger the "check engine light". If the vehicle is late 95 or later, take the vehicle to a shop and have it scanned in "Global OBD II" mode. The mechanic can access "Mode 6" and see if the vehicle has failed any tests and if so which component or monitor circuit it is in.
Old 07-24-2007, 11:21 PM
aznstormin aznstormin is offline
Re: Maxima Codes
Knock sensor won't trigger the CEL
Old 07-26-2007, 02:51 AM
sparkeykev sparkeykev is offline
Send a message via Skype™ to sparkeykev
Re: Maxima Codes
This site can tell you how to acess codes and what codes are
http://www.auto-diagnostic-codes.com/
Old 07-26-2007, 05:28 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Maxima Codes
Raised handbrake handle may keep rear brakes dragging; easily adds consumption +10%. No CEL blinkin, just release the brake ... alas wont help if wires are rusted and/or caliper(s) jammed, possible brake drag problem has to be checked, if exists, corrected. (Raise rear wheel up, has to rotate freely) Check http://www.cardomain.com/ride/748507/18
Engine computer is a hi speed dummy - as all computers are: its ponytail programmers xbox-brains (using imaginary preprogrammed predetermined errorcodes) pose a barrier what this stupido machine can relay to living beings ... humans outside their 'obd-game screen'. This 'missin darwinist dark age link' may cause NO CEL when there is a problem and/or CEL ON when there are no problems. Ooops: one has to exercise common sense.
Take care: this computer carbagein/car_bage_out is being projected on us technobeleivers on many premeditated front$ like in globbal warmup hoax: scientific computer modeling cant predict weather one week ahead, still this same carbage is used to pump up our our taxes - on hundred year forecast bs.
