Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 06-21-2007, 07:08 AM
Channel595 Channel595 is offline
Send a message via AIM to Channel595
intermittent heater
im pretty sure its the switch for the heater but im not certian, it will either work like 100% or not work 100%. one time when it didnt i restarted my car and then i couldnt get it to not work and im not sure on this particular car but when i first got it, it would turn on really slow, is that normal? intermittent problems are a bitch to find.
Old 06-21-2007, 03:56 PM
Towncar's Avatar
Towncar Towncar is offline
Re: intermittent heater
.....and im not sure on this particular car but when i first got it, it would turn on really slow, is that normal?
Yep, "really slow" is the new thing. The engineers figured you don't want an undesirable temperature blasting at you, so they worked it out so that the system will try to reach "your" desired temperature before blasting it.
What year was your's again? I'm thinking this might just be the infamous Blower Speed Control transistor solder problem.
-Steven
1996 Town Car, Cartier
Old 06-22-2007, 10:56 PM
91 towncar
Old 06-23-2007, 12:41 AM
Towncar's Avatar
Have you looked at the Blower Speed Control yet? There's a huge transistor on one side that's not soldered with hi-temp solder, it melts, blower acts odd, then locks on high.
Re-soldering it with better solder does the trick, if that the problem..
There's a writeup at LincolnsOnline, and I have something on my freebie site too (right column).
-Steven
