Old 06-20-2007, 11:19 PM
alphalanos alphalanos is offline
Graphics problem
My system:
Windows XP Pro SP2
Intel P4 2.99 Ghz
1.5 GB ram
ATI Radeon X1650 Pro 512Mb
Antec 430w PSU
ASrock Mobo
When Im playing a game after a short time, 1-2 min, Something in the computer starts making a beeping sound. The sound is simultaneous with a graphic slowdown that happens for a split second at a time, but also in rapid sucession. I have tons of cooling on the card, the ATI CCC shows the card is at about 45C max. Also when I try to use the ATI Overdrive, the screen flickers if I raise the processor clock speed at all.
96 EJ6. Future home of boosted B18C1.
Old 06-20-2007, 11:38 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Graphics problem
Did you try updating drivers?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-21-2007, 12:42 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
113f is pretty cool for a gfx card, most idle at that.. Are you SURE thats the highest the temp has gone? Try motherboard monitor or something else. just to make sure it's not overheating.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 06-21-2007, 12:53 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Definately try some different versions of drivers/firmware.
If you don't have any joy, open the side of the case and stick a desk fan blowing in.
Either way you should have your answer.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 06-21-2007, 09:19 PM
Well I updated the driver but that didn't help. Then I cleaned the little dust that was in the computer out and at the same time threw in a 256mb stick I had laying around. After that the problem went away. So Im guessing there was a conflict with the ram. Probably because its mismatched I guess. Thanks for the help.
Old 06-22-2007, 12:15 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
What exactly did you do with the RAM? Take all RAM out and put in a 256 spare chip you had lying around?
I think it's definately worth investigating the RAM further - do some testing on it, and read the motherboard manual to learn which slots matching RAM should be in - you might have had it in the wrong slots\.
Old 06-22-2007, 08:34 AM
Thats what it was. I just had the ram in the wrong slots. Wouldnt have happened if I had just followed the manual in the first place and matched it all up with the same speeds. HT only works with identical ram, and mine is a combination of 3200/2700 so it was probably getting hung up.
Old 06-23-2007, 02:40 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
I'm glad it's fixed.
